I honestly can't answer your question. I know on some years and some engines the number of teeth on the tone wheel for the crank sensor is different. I don't recall if the V10 has a tone wheel on the crankshaft or if it uses a bellhousing mounted sensor like the 5.2/5.9 magnum v8's and v6's do.
Either way the crank and cam sensors are probably going to be your main issues.
