best way to drill magnum style bolt holes in LA head??
#185684
01/06/09 02:37 PM
01/06/09 02:37 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I am changing direction a bit on my Grand Cherokee build and decided to use my Cordoba 390 parts to rebuild the Magnum 5.2 and get rid of all the other parts I already have. Instead of using the edelbrock magnum heads as planned, I will now use my ported EQ magnum heads but they are the 318B heads that only have the LA style intake bolts. I need to drill and tap the iron EQ heads for the vertical magnum style bolts.
I was thinking about getting a crosswind intake that has both la and magnum style bolt holes and bolting it to the engine using the la bolts. Then, put a metal sleeve in the vertical magnum hole (to prevent damage) and have at it??? Or should I just take it to a machine shop and let them do it?? I could probably use the crosswind intake some time in the future so I have no problem buying one....... I am off from work for 2 months so I have time on my hands...... TIA TBF
Anybody looking for a freshly bored .030 over 70 318 block align honed and decked?
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: best way to drill magnum style bolt holes in LA head??
[Re: tpabayflyer]
#185685
01/06/09 03:00 PM
01/06/09 03:00 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Are you trying to install the OEM barrel ram on those heads?
Using the crosswind intake would probably work decently well. I have one for sale if you plan on getting one.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
