Re: Horsepower on stock Hemi block
[Re: Kevins493]
#1856623
06/25/15 01:49 PM
06/25/15 01:49 PM
Posts: 409 Texas
mprhound
Texas
Bob Banning Dodge used to get about 90 runs at roughly 1800 hp on 80% nitro in their funny car back in the 70s. They would typically crack in the main saddles. When you had to chisel the main bearing out because it got drawn up into the crack it was time to replace the block. Then I should be way safe then!!! Thanks Has anyone else ever seen a factory block like this?
[Re: mprhound]
#1856655
06/25/15 02:22 PM
06/25/15 02:22 PM
Posts: 4,457 Washington
madscientist
Washington
Sounds like an over the counter race block. You should be good to go. Probably even better than a stock hemi was.
[Re: mprhound]
#1856715
06/25/15 03:44 PM
06/25/15 03:44 PM
Posts: 4,700 Wichita
GY3
Wichita
Sounds fun!
What heads are you going to use?
[Re: dogdays]
#1857056
06/25/15 10:16 PM
06/25/15 10:16 PM
Posts: 409 Texas
mprhound
Texas
It would be really cool if you checked the cylinder wall thicknesses and posted them. I'd like to know what the QC was like on the factory race stuff. Back in the day an ultrasonic thickness checker was aerospace only and maybe not available at all. Plus it would be to your own advantage to find out the info for future use.
Thanks, R. The thinnest place is .347
[Re: mprhound]
#1857379
06/26/15 01:23 PM
06/26/15 01:23 PM
madscientist
Washington
Bought here of moparts back in March
I just found a set of Brewer heads that are supposed to flow over 420 Cfm Going to pick one of them up tomorrow to get it to a known flow bench on Saturday to see what they really do, will also pressure test them before I buy. Anybody know where there is a cast brewer intake? I'm just going to say I'd pass on the Brewers. Call T&D or Jesel and talk to them BEFORE you buy. I have offered to flow a Brewer for FREE on a FLOW DATA bench and can't get any takers. I've only seen pictures but my guess is that B-1 MC's will kick the crap out of Brewers for HP. I've been going to the races for years now and I have never seen a set of Brewers run. Probably because I'm on the left coast. But if they were all that you'd think someone out here would do it. In fact, I called T&D about 18 months ago on this very topic. The guy I talked to said he hasn't sold any Brewer rockers since he has worked there (IIRC almost 20 years). Again: BUYER BEWARE.
[Re: madscientist]
#1857473
06/26/15 04:20 PM
06/26/15 04:20 PM
Posts: 409 Texas
mprhound
Texas
Again: BUYER BEWARE. [/quote]
That's why I just picked one up to check it out, pressure test and to flow it, these have a set of t&d 1.7 rockers with them so we will see but defiantly being careful, I am curious about them myself. If I get ahold of these may send one to you to flow and put it out there what they do.
[Re: mprhound]
#1857480
06/26/15 04:36 PM
06/26/15 04:36 PM
madscientist
Washington
That's why I just picked one up to check it out, pressure test and to flow it, these have a set of t&d 1.7 rockers with them so we will see but defiantly being careful, I am curious about them myself. If I get ahold of these may send one to you to flow and put it out there what they do. [/quote] I'd love to do it and I'd post the results and what I think. The other issue is while they are out there, if you beat one up, it's difficult to find a replacement. Same thing goes for valve gear. I know T&D had some on the shelf (not sure on the ratio) but you'd pay big time for them to make one set of something.
[Re: mprhound]
#1930064
10/11/15 11:06 AM
10/11/15 11:06 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
got the brewer heads flowed, they flowed 426 on a local bench. as far as rockers, I got the t&d 1.7 rockers with the heads. but still called t&d and they still sell the rocker set up for a hair over $1600. still wondering about the block, was considering going indy max low deck block, so I could use my existing tti step headers, and help on hood clearance. but they are expensive!! a new set of headers with this block would be cheaper, but still wonder about the strength of this block? I had some Brewers. They were pretty neat. They had center bolt and o ring valve covers. They flowed 430ish with great air speed. I had a cast 4 barrel manifold. I think they only made half the amount of manifold to sets of heads due to people running sheet metal intakes. The biggest issue was valve weight with the long stems. I would recommend TI valves to help save springs.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
