BACK FIRE #185583
01/06/09 12:44 PM
01/06/09 12:44 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
1050 dom,7al3,crank trigg. all i did was build a new short block and put everything back together,now i have to hold the trottle wide open for it to srart and it back fires through the ex.ive benn through the carb,timing ,wires a few times ,WHAT AM I MISSING(no pun intended)
Re: BACK FIRE [Re: bonefish] #185584
01/06/09 01:15 PM
01/06/09 01:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
The basics, valve lash set correctly, firing order with verification of every spark plug wire on the correct cyliner, distributor cap not cracked and so on. I did have one new street Hemi motor that was backfiring on the dyno due to the jetting I changed on a new set of carbs before running them on any motor, put the primary jetting back to stock from the manufacturer and the back firing stop Check the carb jets to make sure there is no trash in the jets plugging them up Same thing on the bleeds IHTHs
Re: BACK FIRE [Re: bonefish] #185585
01/06/09 01:23 PM
01/06/09 01:23 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
ign timing retarded
valve not seated
cam timing
WAXER
Re: BACK FIRE [Re: QWK_ENUF] #185586
01/06/09 01:56 PM
01/06/09 01:56 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
start from the start.
did you degree the cam in. and verify that its in proper? did you adjust the valves right? are the plugs wires correct (check again)
Re: BACK FIRE [Re: aarcuda] #185587
01/06/09 05:58 PM
01/06/09 05:58 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ok TOOK EVERYONES ADVICE AND WENT BACK THROUGH.fixed the back fire,i hate to admitt it but i had 2-4 crossed,still had to hold it to the floor to start so i took the carb back apart and i had a 4150 metring block gasket in my dommy now it starts right up.now if i can just get it to idle.
Re: BACK FIRE [Re: bonefish] #185588
01/06/09 06:37 PM
01/06/09 06:37 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i hate to admit it but plug wires 5 and 7 got me this summer..... DOH!
might wanna take a look at your plugs and get a new set. they are probably tore up. And for idle, you'll want your initial timing pretty high if you have a big cam in there and then you'll be able to back the idle screw back down...
Re: BACK FIRE [Re: bonefish] #185589
01/06/09 11:13 PM
01/06/09 11:13 PM
what idle speed do you want it to idle at? What brand and size Dominator are you running? Is your carb equipt with power valves or not? If so what vacume rating are you currently using and what is the idle vacume in gear?
Re: BACK FIRE [Re: Cab_Burge] #185590
01/07/09 12:51 AM
01/07/09 12:51 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You could of blown the power valves.
Re: BACK FIRE [Re: Cab_Burge] #185591
01/07/09 12:53 AM
01/07/09 12:53 AM
Tampa Fl
K
kens avenger Offline
mopar addict
mopar addict
K
Tampa Fl
Remember in here some don't think you should have a Opinion.. sad fact..
Re: BACK FIRE [Re: Cab_Burge] #185592
01/07/09 08:43 AM
01/07/09 08:43 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ITS A 8896 NO PV I HAVE To TURN THE AIR SCREWS OUT 2 1/2 TURNS TO GET IT To IDLE, i need it to idle STRONG at 1500 otherwise it kills the motor when i put it in gear.
Re: BACK FIRE [Re: bonefish] #185593
01/07/09 02:45 PM
01/07/09 02:45 PM
Have you verified that the throttle blades are open the same amount on both ends of the carb.? If not try that, it sounds like your not idling on the idle circuit now. Also, if you can, see what size the idle bleeds are now on all four corners and post that size. You should be able to have the motor idle at 1000 rpm in nuetral and drop around 100 to 200 rpm when you put it in gear. What is the initial timing at now, can you get the motor to idle at 1000 rpm and check the timing? Another easy thing to try to fix the idle is to get some small wire,.020 or smaller and make some short L that will fit into the idle bleeds to see if the current idle bleeds are to big I like to make my carbs idle at or below 800 rpm in gear and only need around 1/4 to 1 full turn out on the idle mixture screws to idle clean and not stink out the exhaust That usually requires custom tuning the idle circuits and the bleed sizes on all four corners
Re: BACK FIRE [Re: Cab_Burge] #185594
01/07/09 10:45 PM
01/07/09 10:45 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i changed from 49 to 53 on the air bleeds and i had to atually had to turn the air screws out even more so i would guess thats the wrong direction,the blades are even,thats one of the first things i do,timing is now at 36 i tried 34 -38 made no diff.its a crank trigg.and the dist is phased in perfect.so i think i really need to consintrate on that idle circut,maby go the other direction with the air bleeds,ill try your wire techneek first that seems like a good idea,
