Re: Rust prevention for new truck
[Re: gss]
#1855124
06/23/15 01:05 PM
06/23/15 01:05 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
Does any of that work all that well? My wife is from Mass. When we're up there visiting it seems like every truck I see, that's more than a few years old, is already rusting pretty bad.
[Re: gss]
#1855607
06/23/15 11:30 PM
06/23/15 11:30 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
Most rust starts on the INSIDE where all the moisture and crap gets up inside and does its dirty deed and only after its erupting through the skin can you see it and then the real damage is done. Internal cavity wax inside all the nooks and crannies and lots of it does the most good IMO. Undercoating the externals also but getting inside with the protection is just as important and often overlooked. http://3mcollision.com/3m-rust-fighter-i-08892.htmleastwood sells their own flavor in quarts and aerosols as well. Our 1999 Beetle is a pile of junk however VW puts the rest to SHAME on the rustproofing that car got from the factory. From the floor up the side of the car about half way every internal/hidden/boxed structure is coated with a thick layer of cavity wax. On a super hot day with the windows up it actually smells like melted crayons for a moment when you open the door.
[Re: gss]
#1856687
06/25/15 03:09 PM
06/25/15 03:09 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
What is the best way to minimize the rust? Elbow grease. The only way I've found to get keep rust away is to pressure wash it the minute you get home from any form of sloppy. If you are pressed for time it doesn't have to be an all-out wash job, but at the very least make sure you flush the undercarriage until clean water is running off your ride. There's trucks running around here 6 years newer than mine that are blistered and rusting, so I must be doing something right...........
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1860102
06/29/15 11:54 PM
06/29/15 11:54 PM
Posts: 4,990 new jersey usa
11secdart
new jersey usa
I have an 08 H.Q.C. I don`t use it everyday but use it to tow and get around when it snows, It is washed as soon as possible after being driven in the snow. A friend showed me something: In the rear wheel wells up against the outside of the truck there is an inner fender that has three big oval shaped holes that the moisture and crud can get in, I think this is why so many trucks like mine and older are rotting the moisture is getting in there and is getting trapped: I filled the holes real good with silicone sealer, hopefully this helps keep the moisture and crud out.
[Re: gss]
#1862883
07/03/15 03:42 PM
07/03/15 03:42 PM
Posts: 2,531 God's Country Maryland
GODSCOUNTRY340
Here's how to stop the rust and prevent it from happening using something you throw away. Get an oil squirter like the one pictured and squirt your old used motor oil between the bed sides. Instead of throwing your oil away use it to stop the rust. You can squirt oil all the way to the front of the bed inside. Make sure the truck hasn't been driven on a wet road for at least 3 days before doing this. You don't want to trap water in there. You will have oil dripping when you do this so do it outside your garage. You will have to wipe oil off some places for a couple days but that's a lot better than having your truck rust apart. I also squirt it in the front fenders from under the hood, inside the doors through the door latch, into the tailgate and even remove the rubber plugs on the back side of the rocker panels and squirt it in there. If possible drive on a dirt road after you squirt it up to trap the oil in there.
[Re: gss]
#1865188
07/06/15 04:26 PM
07/06/15 04:26 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
I've tried the used oil, (dirty and smelly) the new oil, (drips off over time) the commercial stuff (expensive). They all work, but have there drawbacks as noted. Here is my preference, and it is time tested to prevent rust LONG TERM.
Get a gallon can of wd 40. Mix in 2 cans of STP Oil Treatment, and stir it really good until it is dissolved in the wd40. Put it in an old paint sprayer. Spray it in the doors, inside the door posts, inside the fenders and quarters, rockers, tailgate, box braces, between the box and the cab, above the wheel wells, gas door, backside of bumpers, bumper braces, inside the hood bracing, door hinge areas, the entire bottom side, axles, driveshaft, suspension and springs, get it everywhere except the outer finish. Whatever overspray gets on the finish wipes off easy with no damage. It take an hour and cost less than $25
The wd flashes off over time, and leaves a very thin coat of STP, that clings tenaciously thru rain and snow and car washes. But wipes off with mineral spirits if you ever need to. A re-spray every 5 years or so ensures no rust for ever.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: gss]
#1865251
07/06/15 05:23 PM
07/06/15 05:23 PM
Hemi_Joel
Minnesota
Oops, it is the STP oil treatment. It is thicker than honey. I will edit my original post.
