2000 Ram sway bar links #1853202
06/20/15 02:01 PM
06/20/15 02:01 PM
South San Francisco, Ca
70sixpkrt Offline OP
I need to replace my sway bar end links with some good ones on my 2000 Ram 1500 4x4. Is the Moog #K7453 the ones I need? Do I need to jack up the truck or can I change it with the wheels n the ground?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 2000 Ram sway bar links [Re: 70sixpkrt] #1854231
06/22/15 11:17 AM
06/22/15 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I changed the links on my 2000 2500 4x4 with it on the ground in the parking lot of the parts store I bought them at. The truck had about 180k on the original links.
I don't know what part number you need but I ended up using the '99 down link , it was cheaper by half and available at the parts store. At the time the 2000 up was only available at the dealer and double the price, the only difference was the nut arrangement on one end was changed from a castle nut and cotter pin on the 99 to a lock nut and a shorter stud on the ball joint end of the link.
Re: 2000 Ram sway bar links [Re: 70sixpkrt] #1854508
06/22/15 06:11 PM
06/22/15 06:11 PM
Thanks. I just ordered the Moog #K7453 from Rockauto.
4-speed
3:54 Dana
