Re: D350 to D150 spindle/rear swap. Anyone tried it? [Re: 300by500] #1874884
07/21/15 03:22 AM
07/21/15 03:22 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have the front shaft required to do a 518 swap into a LWB 2wd CrewCab
I got a solid 19 MPG hwy with my carbed Magnum/518 4.10 combo with a 31" tall tire in the rear + lowered CrewCab
Re: D350 to D150 spindle/rear swap. Anyone tried it? [Re: BulletBob] #1875373
07/21/15 10:24 PM
07/21/15 10:24 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
Those are some good MPG numbers! For now I'm just doing the engine swap, if I swap transmissions I want a stick OD in it.
I got some 31+ inch 265/75/16s mounted on the rear wheels over the weekend, but I haven't put them on yet as I'm in the middle of relocating the rear shackle mounts and flipping the front spring hangers. Probably gonna end up with around 4" rear drop and 5" front, the bigger tires should help fill the rear wheelwells a little better. Can't wait to see how it looks!
