Re: Test and tune..... Broke it.....
[Re: B3422W5]
#1856070
06/24/15 06:17 PM
06/24/15 06:17 PM
Quicktree
Appears it broke the rear end, tore cap off. Will know for sure tomorrow 8.75, 489 case, solid spacer. Funny I didn't hear any noticeable noise pushing it.
I pray Quicktree doesn't see this post........ Lol I didn't see a thing, but I thought you were one of the guys telling us how great they are? now you have to pull the tranny and check it also. really sorry to hear it though.
[Re: Quicktree]
#1856097
06/24/15 06:50 PM
06/24/15 06:50 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I pray Quicktree doesn't see this post........ Lol I didn't see a thing, but I thought you were one of the guys telling us how great they are? now you have to pull the tranny and check it also. really sorry to hear it though. Nope not me. I ran an 8.75 in my old car. Lived a couple years at 11.70's, couple more years running 10.70's, and then when I stepped it up it grenaded and went straight to a Dana and never looked back. Gonna put it back together and hope this little 318 doesn't bust it again.... Lol I will feel like an idiot running a Dana with a 318, hope it doesn't come to that.... It's only 475 horse once I get it dialed in..... And I think I have, just need to not break anything now to find out.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1856113
06/24/15 07:28 PM
06/24/15 07:28 PM
B3422W5
Portage,michigan
Don't think it was, no external damage, and zero leaks.... 904...
[Re: B3422W5]
#1856121
06/24/15 07:41 PM
06/24/15 07:41 PM
Quicktree
Don't think it was, no external damage, and zero leaks.... 904... check it anyway or it could be in your lap
[Re: B3422W5]
#1856123
06/24/15 07:43 PM
06/24/15 07:43 PM
B3422W5
Portage,michigan
Will do. It's at a tranny guys shop I know.
[Re: B3422W5]
#1856131
06/24/15 07:59 PM
06/24/15 07:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Trans is probably hurt also, seen it to many times after breaking rear. Please pull trans apart for a look see.
Mopar to the bone!!!
[Re: B3422W5]
#1856133
06/24/15 08:00 PM
06/24/15 08:00 PM
72Swinger
Nebraska
Talk about guys all posting at once haha.....
[Re: B3422W5]
#1856162
06/24/15 09:05 PM
06/24/15 09:05 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
check the rollers and springs in the sprag
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: B3422W5]
#1856233
06/24/15 10:37 PM
06/24/15 10:37 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Dang sounds like my last trip to the track. My car did make one poor pass before my spinning and then hook pass. I thought it was good until I went to launch the car and it went into what felt like a neutral . I found it still pulled a little so I tried to shift to second and it locked up completely. Found the sprag came apart and lock the rear drum. When the rear band applied it locked up. Now waiting on my new super sprag for my 727. Oh by the way mine is a 318 422 cube engine too
6.50 @105.26
[Re: Kindafast]
#1856242
06/24/15 10:53 PM
06/24/15 10:53 PM
B3422W5
Portage,michigan
Dang sounds like my last trip to the track. My car did make one poor pass before my spinning and then hook pass. I thought it was good until I went to launch the car and it went into what felt like a neutral . I found it still pulled a little so I tried to shift to second and it locked up completely. Found the sprag came apart and lock the rear drum. When the rear band applied it locked up. Now waiting on my new super sprag for my 727. Oh by the way mine is a 318 422 cube engine too Mine is a 323 cubic inch 318 block magnum motor in my Duster that broke My old car/ motor was a 422 W5 mill Just never changed my screen name.... Lol
[Re: Quicktree]
#1856610
06/25/15 01:34 PM
06/25/15 01:34 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
you will be lucky if the tranny case is not destroyed Not so fast there Mr. doom and Gloom ... for some odd reason the 904 is not as acceptable to the sprag woes of the 727 , but he needs to look at it anyway ...
[Re: JohnRR]
#1856616
06/25/15 01:40 PM
06/25/15 01:40 PM
Quicktree
you will be lucky if the tranny case is not destroyed Not so fast there Mr. doom and Gloom ... for some odd reason the 904 is not as acceptable to the sprag woes of the 727 , but he needs to look at it anyway ... yea i over looked the 904, thanks for pointing that out Mr. Cheerful
[Re: B3422W5]
#1856692
06/25/15 03:17 PM
06/25/15 03:17 PM
B3422W5
Portage,michigan
Buddy of mine looking at it just sent me a picture. The axles are stripped. Looks like only about 1/2 to 3/4 inch of the splines were engaged . So measuring the rare ds looks like mine is 54 and an A body is 52 Sooo..... I didn't know the rear that was in the car when I bought it was out of a B body Need to order some B body axles....... I am guessing correct axle spine engagement should be roughly 1.5 inches into the spool on both sides?????????
[Re: B3422W5]
#1856716
06/25/15 03:44 PM
06/25/15 03:44 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Buddy of mine looking at it just sent me a picture. The axles are stripped. Looks like only about 1/2 to 3/4 inch of the splines were engaged . So measuring the rare ds looks like mine is 54 and an A body is 52 Sooo..... I didn't know the rear that was in the car when I bought it was out of a B body Need to order some B body axles....... I am guessing correct axle spine engagement should be roughly 1.5 inches into the spool on both sides????????? Common problem. The issue is the split gear setup on MOST 8.75s. Each axle engages a side gear AND a side 'plate' that is part of the clutch assembly of the sure grip. That means of the engagement of the axle-to-side-gear strips out you go nowhere. Not only are the axle splines trashed, but so are the side gears (at least one) in the diff unit. A much better design was the one piece where by the side gear and plate are one unit, but they are rare. The side gear and plate are locked together when an axle is installed so they FUNCTION as a single piece, unless, as in your case the small amount of axle spline to side gear engagement strips out.
[Re: Pacnorthcuda]
#1856736
06/25/15 04:06 PM
06/25/15 04:06 PM
Posts: 2,074 CA
crackedback
CA
Buddy of mine looking at it just sent me a picture. The axles are stripped. Looks like only about 1/2 to 3/4 inch of the splines were engaged . So measuring the rare ds looks like mine is 54 and an A body is 52 Sooo..... I didn't know the rear that was in the car when I bought it was out of a B body Need to order some B body axles....... I am guessing correct axle spine engagement should be roughly 1.5 inches into the spool on both sides????????? Common problem. The issue is the split gear setup on MOST 8.75s. Each axle engages a side gear AND a side 'plate' that is part of the clutch assembly of the sure grip. That means of the engagement of the axle-to-side-gear strips out you go nowhere. Not only are the axle splines trashed, but so are the side gears (at least one) in the diff unit. A much better design was the one piece where by the side gear and plate are one unit, but they are rare. The side gear and plate are locked together when an axle is installed so they FUNCTION as a single piece, unless, as in your case the small amount of axle spline to side gear engagement strips out. From his comments this is not the issue, he has a spool. Axles too short are the root issue. Sorry to read about this Don. Hope the spool isn't hurt. Pull it all down, flush out the garbage, measure and start over. Hopefully most all the junk is in the bottom section of your housing. Might be a good time to install a drain plug in the bottom of your housing.
[Re: B3422W5]
#1856916
06/25/15 07:36 PM
06/25/15 07:36 PM
B3422W5
Portage,michigan
Bought CORRECT length 35 spine axles and new 35 spline spool to replace the 30 spline stuff I had Dr Diff is as always a great guy to deal with Hope to get out soon and give it another try. Cass said it probably wouldn't have stripped if I had 35 spline to begin with, even with the shallow engagement. Should have listened to him the first time
[Re: B3422W5]
#1857279
06/26/15 09:55 AM
06/26/15 09:55 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Glad it was an easy fix. Check the trans out yet?
