Test and tune..... Broke it.....Tranny
#1852856
06/19/15 10:42 PM
06/19/15 10:42 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Get car sorted out, do burnout... Stage it.... Launch it( just off idle at 1500 and revs up like in neutral. And breaks. 904 No forward gears or reverse. No noises rolling it around. Not sure what I broke First time out this year, made some nice changes, not meant to be... Lol
Re: Test and tune..... Broke it.....
[Re: B3422W5]
#1852897
06/19/15 11:32 PM
06/19/15 11:32 PM
B3422W5
Portage,michigan
Local guy built it who does most of the 904/727 stuff for US131 racers. Billet servo's A&A footbbrake valve body. As far as I know otherwise stock internals.
[Re: B3422W5]
#1852926
06/19/15 11:58 PM
06/19/15 11:58 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Major bummer. Get her fixed and go get em.
[Re: B3422W5]
#1852972
06/20/15 12:55 AM
06/20/15 12:55 AM
B3422W5
Portage,michigan
No park either. Car rolls easily and acts likes its in neutral in all gears
[Re: B3422W5]
#1852977
06/20/15 01:03 AM
06/20/15 01:03 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not pump ears then. Dig deeper
[Re: B3422W5]
#1852979
06/20/15 01:06 AM
06/20/15 01:06 AM
B3422W5
Portage,michigan
Pushed it up on the trailer and put it in park... As it was flat didn't notice it didn't hold until started putting a little tension on straps..... Oops. Back at my store in its bay safely, now have to figure out what's broke.
[Re: Twostick]
#1853029
06/20/15 03:12 AM
06/20/15 03:12 AM
Posts: 2,080 CA
crackedback
CA
Sounds like the output shaft is FUBAR.
This is assuming the engine is turning but the driveshaft isn't.
Kevin Agreed, sounds as though it broke aft of the parking pawl point
[Re: B3422W5]
#1853379
06/20/15 08:13 PM
06/20/15 08:13 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Hopefully it's something fairly simple Don, breakage is no fun.
[Re: B3422W5]
#1856053
06/24/15 05:47 PM
06/24/15 05:47 PM
B3422W5
Portage,michigan
Appears it broke the rear end, tore cap off. Will know for sure tomorrow 8.75, 489 case, solid spacer. Funny I didn't hear any noticeable noise pushing it.
I pray Quicktree doesn't see this post........ Lol
