Scarebird disc brakes? #1852324
06/19/15 01:37 AM
06/19/15 01:37 AM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Finally got back into a 74 duster after a year sabbatical of no Mopars. This is an odd car, 4/74 build date but is still small bolt and drums shruggy. Anyway, I thought of using the Scarebird caliper mounts to do the disc conversion. Does anyone have any feedback on these kits?
Re: Scarebird disc brakes? [Re: SLOW67] #1852325
06/19/15 01:39 AM
06/19/15 01:39 AM
CA
crackedback Offline
crackedback  Offline
CA
They work pretty good.
Drum brake A bodies were SBP until the Disc requirement came into effect.
Re: Scarebird disc brakes? [Re: SLOW67] #1852360
06/19/15 02:56 AM
06/19/15 02:56 AM
Nigeria
Techie Offline
Techie  Offline
Nigeria
hhh..how i feel
Re: Scarebird disc brakes? [Re: SLOW67] #1852423
06/19/15 10:57 AM
06/19/15 10:57 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
My situation probably no longer applies. I got my B-body set about 10 years ago. I know they've changed things since then, but I had to do some machine work to make everything fit. I wasn't too pleased with the brackets right out of the box.
However, once that was taken care of they're a very cost effective alternative for a driver, and I'm sure they're fit has gotten better in the last 10 years.
My kit used late 90's GM truck calipers with early 70's Fury rotors.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
