Need some info on restoring Cuda Taillight assemblies #185215
01/05/09 11:17 PM
01/05/09 11:17 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Can anyone tell me what finish was applied to the 70 and 71 Cuda cast taillight housings? Any pics?
Also, what finish of black, (flat, low gloss or satin) was applied to the cast louvers or grills that went over the lenses? Pics?
Re: Need some info on restoring Cuda Taillight assemblies [Re: BADBEE] #185216
01/06/09 09:39 AM
01/06/09 09:39 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Jeff,
As far as I know there isn't anyone that replates
them (housings)you may try the eastwood 2 stage paint green,gold for the housings. Do sample pieces first so you get the shading you want. The grilles are the same as the tail panel organisol black.
logan426
Re: Need some info on restoring Cuda Taillight assemblies [Re: BADBEE] #185217
01/06/09 10:53 AM
01/06/09 10:53 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Resto Rick redoes that plating process on the taillight housings.
Re: Need some info on restoring Cuda Taillight assemblies [Re: 71TA] #185218
01/06/09 10:58 AM
01/06/09 10:58 AM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
So they plated the pot metal?
Thats what it loooked like, but I wonder why?
To keep them from turning into powder?
Re: Need some info on restoring Cuda Taillight assemblies [Re: BADBEE] #185219
01/06/09 11:49 AM
01/06/09 11:49 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Need some info on restoring Cuda Taillight assemblies [Re: MLR426] #185220
01/06/09 07:41 PM
01/06/09 07:41 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Doesnt organosol have a texture to it???
Re: Need some info on restoring Cuda Taillight assemblies [Re: BADBEE] #185221
01/13/09 10:16 PM
01/13/09 10:16 PM
Ohio
3404 Offline
3404  Offline
Ohio
Actually they were not plated but ran through a chromate when they were new to "seal" the zinc die-cast to protect them. They are tough to clean and get the chromate to penetrate when they are this old but it can be done. I'll try to find some pictures of the casting I have done.
