'70 Challenger T/A Hood Install #1851767
06/18/15 12:34 PM
06/18/15 12:34 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
I just received a t/a hood from AAR Fiberglass and would like to do a factoryish install. I am trying to get a comprehensive parts list together. Thanks for your comments and help! 440 car if that matters.
1)Hood Pin set-different between fiberglass and Metal hood? best source?
2)Hinges-believe these are the same just different springs
3)hood to cowl seal
4)front of hood molding-different between steel and fiberglass hood?
5)Fratzog emblem, I think?
6)Hood bolts, anything special?
7)washer nozzles
6)What have I missed?
7)the pins hold the front down right? No other form of retention in front?
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1851832
06/18/15 02:06 PM
06/18/15 02:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1 - Yes, you need a kit with the rivets for a 'glass hood.
2 - Yes, lighter springs, hinges are the same.
3 - Same rear seal.
3.5 - Front seal to radiator support has the ends trimmed off.
4 - Same molding, but you use longer studs. R/T Specialties has them.
5 - No emblem.
6. Same as any other 1970 hood.
7 - www.fpap.com has them for sale.
8 - See 3.5 above.
9 - Pins only, no center latch or pop up spring.
Re: '70 Challenger T/A Hood Install [Re: Alaskan_TA] #1851908
06/18/15 03:37 PM
06/18/15 03:37 PM
Berwyn, IL
Berwyn, IL
Awesome, thanks!
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1852016
06/18/15 06:16 PM
06/18/15 06:16 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
And even though it is new, it will bow. I have a AAR T/A hood on my T/A with teh correct hinge springs and it has bowed. I got it 7 years ago. If you don't want it to bow, don't use the springs.
1970 Dodge Challenger T/A
Re: '70 Challenger T/A Hood Install [Re: jeff968] #1852035
06/18/15 06:36 PM
06/18/15 06:36 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I used the light weight springs from Year One
They worked out great,,,,
I know some people fab up a "prop rod" that also seems to work well...
I just installed a AAR T/A hood on my 70 Challenger..
Re: '70 Challenger T/A Hood Install [Re: 69CHARGERMD] #1852040
06/18/15 06:41 PM
06/18/15 06:41 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: '70 Challenger T/A Hood Install [Re: 69CHARGERMD] #1854387
06/22/15 02:55 PM
06/22/15 02:55 PM
Berwyn, IL
Berwyn, IL
Nice, I am excited about mine, I have had a crappy 6pack knockoff hood on my Challenger since I got it. Do you recall how long the hood pin cables are? Where did you get your hardware? Looks like I can find 2-3 things at 3 different places, just wondering if anyplace has everything?
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1854398
06/22/15 03:13 PM
06/22/15 03:13 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
How do you all like the AAR, T/A hoods how do they compare to original. I have an AAR Cuda and I need a new hood and I was considering a Year One wasn't sure about the AAR hoods.
Re: '70 Challenger T/A Hood Install [Re: joes68340s] #1854400
06/22/15 03:18 PM
06/22/15 03:18 PM
Berwyn, IL
Berwyn, IL
Not having an original I can't compare but it seems like very high quality, ready for paint. I haven't heard of a better source for non-original hoods. twocents
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1854414
06/22/15 03:33 PM
06/22/15 03:33 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Since its not a show car or matching numbers just a nice driver it dosent matter how well it looks underneath. Glad you and others like there hoods.
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1854419
06/22/15 03:36 PM
06/22/15 03:36 PM
Berwyn, IL
Berwyn, IL
Not that I don't believe you Alaska t/a but are we sure about the trim being the same between steel and t/a hood? I just saw in the book "Original Challenger and Barracuda 1970-1974 By Jim Schild" he mentions a special part number 3420000 edge molding for the t/a hood.
P.27
https://books.google.com/books?id=FNfbub...0ch&f=false
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1854432
06/22/15 03:47 PM
06/22/15 03:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The trim itself is the same.
If it came with the longer studs, it did have a different part number, but the fasteners can be changed in minutes.
Re: '70 Challenger T/A Hood Install [Re: Alaskan_TA] #1854440
06/22/15 03:54 PM
06/22/15 03:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
3420 000 was for the molding package, which did include the fasteners. Fastener number is 6002 320
Steel hood molding package was 3549 699 & the fastener part number is 6002 170.
The only difference is the length of the fasteners & the nuts, the molding itself is the same.
Re: '70 Challenger T/A Hood Install [Re: Alaskan_TA] #1854473
06/22/15 04:27 PM
06/22/15 04:27 PM
Berwyn, IL
Berwyn, IL
Thanks again, I had bought a molding many years ago and I was hoping it was ok to use. up
I should have known better than to question you.
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1854554
06/22/15 05:58 PM
06/22/15 05:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No one is infallible, question any time you have a doubt.
Re: '70 Challenger T/A Hood Install [Re: joes68340s] #1854603
06/22/15 06:30 PM
06/22/15 06:30 PM
Berwyn, IL
Berwyn, IL
Underside looks good too, here is a pic of it laying in place on my car as delivered.
Re: '70 Challenger T/A Hood Install [Re: joes68340s] #1854761
06/22/15 09:16 PM
06/22/15 09:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Go with the Year One hoods, they are made by ASC&P International in Eagle, Pa. you won't find a better repro currently on the market
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1857330
06/26/15 10:48 AM
06/26/15 10:48 AM
Berwyn, IL
Berwyn, IL
Being they were used as replacements when the factory ran out of shakers are there any factory 440 emblems that were ever used on the T/A Hood? Which ones work if so.
Re: '70 Challenger T/A Hood Install [Re: challenger70] #1857405
06/26/15 01:22 PM
06/26/15 01:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The shaker hoods were available again about the same time as the T/A hoods came out, the 'replacement' rumor scenario was debunked years ago.
Re: '70 Challenger T/A Hood Install [Re: DAYCLONA] #1857412
06/26/15 01:31 PM
06/26/15 01:31 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
The ASC&P hoods rock. I have one. Looks original.
ONLY problem i have with mine and may redo is the steel mesh (like cowl vents) at the back of the hood rust after time. Personally I'm a HUGE fan of stainless. I'm gonna change mine out to stainless even if I have to get it custom water jet cut to look the same. It get painted over with organisol anyway so know one will know except it wont rust.
If I had it to do over I'd contact Barry (think his name was) direct and ask if he could get SS or if I could supply the pieces before he builds the hood.
If not concerned about original looking the AAR hood looks GREAT.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: '70 Challenger T/A Hood Install [Re: Alaskan_TA] #1857541
06/26/15 05:11 PM
06/26/15 05:11 PM
Berwyn, IL
Berwyn, IL
Sounds like that book "Original Challenger" is full of all kinds of BS down Thanks for the info again as always beer
