440 Rear Main Seal Leak--Almost Suicidal!! UPDATE
#1851379
06/17/15 10:25 PM
06/17/15 10:25 PM
Posts: 1,051 The Great White North
RAMM
I need some serious help here. The battle I have been having with this rear main seal is going to affect my health-seriously.
The saga begins: Customer brings previously rebuilt (18 years ago) 440 in for freshening/updating.
It is a 440 with a NEW stock stroke Eagle crank, Eagle H beam rods, reused Wiseco pistons, 915 heads etc...
Customer has a 69 RoadRunner 4 spd car and he is the original owner.
1st attempt: Engine runs great on the dyno but seal leaks a few drops.
2nd attempt: I figure I missed something with his original retainer and proceed to get pan gaskets ordered so I can take pan off and "fix" rear main. I remembered that I did not have any venting or breathing in the valvecovers except for his original PCV valve hooked into the back the carb. I figured I generated too much crankcase pressure the first time. Hook engine to dyno and fire it up with open valve covers--no leaks until I complete one short pull. Engine makes great power but leaks again--same spot.
3rd attempt: Customer is awesome and supplies a Mancini billet retainer. I verify endplay .005", crank seal journal out of round .0013" and assemble with new Victor rubber seal. All looks good and normal. Re-dyno. Warm engine up---leaks worse than before. No pulls are performed.
4th attempt: Tear down, remove crank, install rope seal left over from a Pontiac gasket set. Polish seal journal with highspeed crank polisher. Feels better, looks better. Re-dyno. Leaks same as before. Install pressure gauge on dip tube and really look for signs of blowby none detected.
5th attempt: Tear down, hand grind with pencil grinder "anti-leak" grooves into rear main. The grooves point forward and this looks like it may do the trick. Prepare different rear main retainer (OEM)surface .005" in cap grinder (per my usual prep). Install another new rear main rubber seal with aviation sealer under rubber halves instead "RightStuff". Re-dyno ran engine 1300-1500 rpm for 15 minutes while I layed on the floor with a flashlight watching rear main. On the 13th minute a leak began right before my eyes. Remove engine from dyno and back on the stand. All signs are pointing to a rear seal area that is too rough or something.
6th attempt: Send crank to crank shop where seal journal is ground .005" and built back up with chromium ($$$$$) and finish ground. Crank shop assures me he has seen this many times and this is the only fix.At the same time block is torn down and re-honed/ re ringed to rule out blowby. I check the seal surface for out of round this time it is better (.0009") This time a new Fel-Pro "red" is installed and carefully (You have no idea) put into place.Back on the dyno and engine runs great like usual. I nervously watch the clock and the floor. 20 mins passes--crank flange and block is bone dry!! I run out of fuel. Get fuel, refire, warm-up, complete pull 4000-5000 rpm. LEAKS!!!!!!!!! Not much but it will not get better by itself.
Conclusion: I have built approx two dozen (maybe more) Mopar big blocks in my life and have never even been this careful and I have never ever had a leak. I have "influenced" the retainer to one side, I have feeler gauged it forward into correct alignment as measured, I have taken every conceivable measure to correct this.I had a small block Mopar leak on me once that was the result of a messed up linebore. It was remedied with a rope seal. I have a Fel-pro rope seal on the way. Short of ordering a NEW Scat crank I don't know what else to try. Keep in mind this thing has a tray and I have effed up 12 gaskets at this point.
This engine was not leaking when it came in and no line hone was performed.
The only thing that has really changed is the new Eagle crank. I am open to any and all suggestions/ experiences.
Surely somebody has gone through this. Yes I have done more online searching and reading than I care to admit. Yes the knurling is in the correct direction as the OEM crank.(It does not have knurling now) Yes it has the crank deflector just like the OEM crank. Yes I have checked the diameter of the seal journal. It is the same as the OEM crank. Yes I have installed the seal retainer with the crank removed from the block twice--it is nice and round and inline for and aft. This is not making sense. Maybe I can't see the forest for the trees? Any and all help sincerely appreciated--J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: 440 Rear Main Seal Leak--Almost Suicidal!! (Long)
[Re: RAMM]
#1851421
06/17/15 11:05 PM
06/17/15 11:05 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Studs or stock main bolts? if studs, #5"s are hitting the back of the pan. Not the main seal at all. Been there done that. Other than that . don't know what to tell ya.
[Re: Cheatham]
#1851438
06/17/15 11:13 PM
06/17/15 11:13 PM
rowin4
It's not that the studs are to long , the nuts are longer and hit on the curved back of the pan causing it not to pull down tight. To the original poster: look at the back inside of the pan and see if there are 2 marks where the heads of the bolts are hitting.
[Re: rowin4]
#1851497
06/18/15 12:15 AM
06/18/15 12:15 AM
RAMM
Studs or stock main bolts? if studs, #5"s are hitting the back of the pan. Not the main seal at all. Been there done that. Other than that . don't know what to tell ya. Sorry, yes studs. Definitely not the pan. Ran the engine and observed leaks without slinging it everywhere. Leak is plain as day running down from the seal journal ABOVE the pan. Thanks though. J.Rob
[Re: Cheatham]
#1851501
06/18/15 12:17 AM
06/18/15 12:17 AM
RAMM
you said it has a tray, so does it have main studs ? if so then chances are the rear studs are holding the pan from sealing at the rear and thats where the leak is coming from. Not a pan leak. J.Rob
[Re: rowin4]
#1851509
06/18/15 12:20 AM
06/18/15 12:20 AM
RAMM
Studs or stock main bolts? if studs, #5"s are hitting the back of the pan. Not the main seal at all. Been there done that. Other than that . don't know what to tell ya. Studs. No witness marks at all on pan. Pan pulls down tight. Thankyou though. J.Rob
[Re: Pacnorthcuda]
#1851530
06/18/15 12:46 AM
06/18/15 12:46 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
RAMM....Welcome to my hell. I feel your pain. What is the cast date of the block you are having issues with? My saga is documented in the following thread. http://a12mopar.com/yabb/YaBB.pl?num=1424822394/15I finally gave up and am just going to deal with it as a maintenance item on the car. D
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: a493demon]
#1851572
06/18/15 02:06 AM
06/18/15 02:06 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Do you offset the seal so it doesn't line up with the split between the block and retainer ? I would try this. DON'T glue the seal in the block, nor in the cap. Only glue bottom and sides of seal retainer. Seal joints 90* from retainer surface. Never had one leak done this way. And of course I HATE to ask an obvious question.....but you are turning the lip on the seal the right way?
[Re: Project kickin A]
#1851601
06/18/15 03:13 AM
06/18/15 03:13 AM
Monte_Smith
North Alabama
I might suggest that the crank journal for the seal area has been turned down to small? I dunno but Ive heard of eagle cranks having a snout that's to small for a damper by a few thou He already said it has been cut, rewelded and measures correct
[Re: Pacnorthcuda]
#1851645
06/18/15 08:50 AM
06/18/15 08:50 AM
RAMM
Cracked block, at or above the scene of the leak? Starting to wonder about this as well. Only problem with this is the block was dry at the back when I took it apart and I seriously doubt it has ran enough or has been traumatized enough to crack. Thanks though. J.Rob
[Re: a493demon]
#1851647
06/18/15 08:53 AM
06/18/15 08:53 AM
RAMM
Do you offset the seal so it doesn't line up with the split between the block and retainer ? I have tried both lined up and offset about 3/16". When I install the retainer I can "feel" the seal halves engaging into the retainer/block grooves. Thanks J.Rob
[Re: Monte_Smith]
#1851648
06/18/15 08:54 AM
06/18/15 08:54 AM
RAMM
I might suggest that the crank journal for the seal area has been turned down to small? I dunno but Ive heard of eagle cranks having a snout that's to small for a damper by a few thou He already said it has been cut, rewelded and measures correct Correct it was measured after attempt #2 and it measured correct. Now it has been ground, welded and reground and left on the high end of the spec. Thanks, J.Rob
[Re: quickd100]
#1851651
06/18/15 08:59 AM
06/18/15 08:59 AM
RAMM
I've seen the rear main studs interfere with the seal retainer. (Actually hit the seal retainer holding it off it's mating surface.)Dave Dave, I am fully aware of the studs and the havoc they can wreak on a Mopar. ex ( enlarging thrust cap bolt holes to 17/32" for thrust cap alignment) So yes, I have scalloped the retainer out around studs and nuts. The Mancini cap was also relieved as it extra material in that vicinity, and would definitely hang up there. Furthermore, when I take this apart I always witness the mating surface and how the thin layer of sealant is completely squeezed out and leaves the shape of the retainer. Pics on the way. Thanks though, J.Rob
[Re: Monte_Smith]
#1851652
06/18/15 09:03 AM
06/18/15 09:03 AM
RAMM
Do you offset the seal so it doesn't line up with the split between the block and retainer ? I would try this. DON'T glue the seal in the block, nor in the cap. Only glue bottom and sides of seal retainer. Seal joints 90* from retainer surface. Never had one leak done this way. And of course I HATE to ask an obvious question.....but you are turning the lip on the seal the right way? Monte, So you turn the seal 90* so the seam/parting line will be at the 12 0'clock and 6 o'clock position? I am willing to try anything at this point but fail to see how this helps. The seal lips are facing inward-believe me when I first took it apart I was hoping I had it backwards for an easy explanation. Thanks though, J.Rob
[Re: Big D A12]
#1851657
06/18/15 09:30 AM
06/18/15 09:30 AM
RAMM
RAMM....Welcome to my hell. I feel your pain. What is the cast date of the block you are having issues with? My saga is documented in the following thread. http://a12mopar.com/yabb/YaBB.pl?num=1424822394/15I finally gave up and am just going to deal with it as a maintenance item on the car. D Wow just read through all of it. Is your crank an Eagle?(Nevermind I see it is OEM) My block is a '68 that was cast on Hallowe'en! WTF? J.Rob
[Re: rickraw]
#1851663
06/18/15 09:55 AM
06/18/15 09:55 AM
RAMM
I'm sure u did this, but I'll ask anyway. Is the seal retainer flush with the back of the block? Maybe there is a misalignment issue. Last one I did, I put the seal & retainer in with no crank & checked to see how the parting lines lined up. Did this. No crank in block, seals in, everything was nice and round. Parting lines almost not detectable by finger. Did this twice actually. Thanks, J.Rob
[Re: RAMM]
#1851687
06/18/15 11:07 AM
06/18/15 11:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm sure u did this, but I'll ask anyway. Is the seal retainer flush with the back of the block? Maybe there is a misalignment issue. Last one I did, I put the seal & retainer in with no crank & checked to see how the parting lines lined up. Did this. No crank in block, seals in, everything was nice and round. Parting lines almost not detectable by finger. Did this twice actually. Thanks, J.Rob When you put it in the block with no crank.. did you have the side seals in it.. I have seen where the retainer was cut shallow on one side.. it forces the retainer over... this was a after market retainer
[Re: MR_P_BODY]
#1851688
06/18/15 11:11 AM
06/18/15 11:11 AM
RAMM
I'm sure u did this, but I'll ask anyway. Is the seal retainer flush with the back of the block? Maybe there is a misalignment issue. Last one I did, I put the seal & retainer in with no crank & checked to see how the parting lines lined up. Did this. No crank in block, seals in, everything was nice and round. Parting lines almost not detectable by finger. Did this twice actually. Thanks, J.Rob When you put it in the block with no crank.. did you have the side seals in it.. I have seen where the retainer was cut shallow on one side.. it forces the retainer over... this was a after market retainer No side seals were in, but I also fill the side channels with RightStuff when I install--so no side loading is present in this case. J.Rob
[Re: RAMM]
#1851750
06/18/15 01:15 PM
06/18/15 01:15 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I used phosphorescent dye (works with a black light) to check a set of heads. They lit up like a Christmas tree at every crack. If there is a dye like this that can be safely used with motor oil, you could trace the leak easily.
[Re: RAMM]
#1851770
06/18/15 01:39 PM
06/18/15 01:39 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#1851784
06/18/15 02:08 PM
06/18/15 02:08 PM
Posts: 447 NJ
JCCuda
NJ
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved I am not aware of this hole. Does anyone have a picture that shows the location of this hole?
[Re: poppaj]
#1851788
06/18/15 02:20 PM
06/18/15 02:20 PM
RAMM
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved I just checked a '70 440 block I had bare here. There is no hole that I can find? J.Rob
[Re: Monte_Smith]
#1851839
06/18/15 03:12 PM
06/18/15 03:12 PM
dartman366
Mt. Vernon, Ohio
plug at the cam tunnel just above the rear main seal seeping?, damhik especially the welch plugs.
[Re: 9secondsatellite]
#1851887
06/18/15 04:02 PM
06/18/15 04:02 PM
RAMM
I know this might be a stretch but what are the odds of the seal journal on the crank not being in line with the rest of the crank? or the other way. the crank seal retaining area not in line with the line bore? i wouls at least try to check that part on the crank, seeing that that might be the 1 thing that has changed in the previous setup. I would think this would show up when I lay crank in mains and set dial indicator on seal journal and it displays .0009" out of round. I called Eagle today and they say they keep it at .0005" or 5 tenths. They were of no help of course. Also when I have had the crank out and installed the retainers-the seal halves line up nicely and I mean round and inline with each other. J.Rob
[Re: RAMM]
#1851933
06/18/15 05:04 PM
06/18/15 05:04 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
I know this might be a stretch but what are the odds of the seal journal on the crank not being in line with the rest of the crank? or the other way. the crank seal retaining area not in line with the line bore? i wouls at least try to check that part on the crank, seeing that that might be the 1 thing that has changed in the previous setup. I would think this would show up when I lay crank in mains and set dial indicator on seal journal and it displays .0009" out of round. I called Eagle today and they say they keep it at .0005" or 5 tenths. They were of no help of course. Also when I have had the crank out and installed the retainers-the seal halves line up nicely and I mean round and inline with each other. J.Rob yeah that should have been good at that point. another thought would be to look at the oil feed hole on the crank for that main. is it pointed to that direction? maybe drilled incorrectly so that it would direct oil flow towards seal? seems at this point like oil is aiming directly at the seal instigating the problem.
[Re: sasquatch]
#1851944
06/18/15 05:29 PM
06/18/15 05:29 PM
9secondsatellite
alaska,usa
Plug the valve covers up and put some air in it and try soap bubbling the seal area. I know of several top shelf mopar engine builders who are ready to rip their hair out right now over these dang seals. Todd i like that idea. i'll try to remember that one in the future.
[Re: sasquatch]
#1851945
06/18/15 05:29 PM
06/18/15 05:29 PM
RAMM
Plug the valve covers up and put some air in it and try soap bubbling the seal area. I know of several top shelf mopar engine builders who are ready to rip their hair out right now over these dang seals. Todd Forgot to mention that--On attempt #4 I rigged an air fitting right where the sending unit comes out of the back of the block. I pressurized it with up to 5 psi and sprayed the crank flange--no bubbles. I realize I may have to pressurize crankcase but really at that point I may as well dyno it and bring it up to temp. I have already proven it a few times--no leaks until you rev it up @ temperature.Thanks though. J.Rob
[Re: RAMM]
#1851953
06/18/15 05:45 PM
06/18/15 05:45 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It might pay to try an electric vacuum pump off a new car. They can be bought pretty cheap. Pretty sure Summit even carries one now.
[Re: JCCuda]
#1851973
06/18/15 06:08 PM
06/18/15 06:08 PM
poppaj
reynoldsburg,ohio
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved I am not aware of this hole. Does anyone have a picture that shows the location of this hole? The hole is just over the main bearing, it was clogged with machining debris I must add this was on a Indy Maxx aluminum block, but is was causing the exact problem you have
[Re: poppaj]
#1852021
06/18/15 07:21 PM
06/18/15 07:21 PM
RAMM
Here's the 3 retainers that have been tried. You can see the clearancing for the studs/nuts. J.Rob
[Re: RAMM]
#1852027
06/18/15 07:27 PM
06/18/15 07:27 PM
RAMM
Studying this closely I think I may have to provide more clearance between the #5 cap rear and the "deflector" on the crank. The black squiggle is where I could machine .057" off. It may do the trick. I really don't think there is any issue with the seal itself. I am leaning towards a severe oil/pressure buildup that NO seal can handle. I'm also starting to think the windage tray should be left out to provide more room between the rear counterweight and the cap. J.Rob
[Re: ross]
#1852151
06/18/15 10:15 PM
06/18/15 10:15 PM
RAMM
RAMM Did you happen to tank the block really good before the rebuild. I read a piece by Rick Ehrenburg a few years ago and he stated that some blocks because of poor manufacturing were porous at the rear and were sealed by some coating applied to the block at the factory.He warned about possible oil leaks after a good tank cleaning as it could remove this sealant. In your case it may be seeping just above the crank and presenting itself as a seal leak. I sure feel for you on this one. Ross This is actually something the customer suggested to me this morning. I do not have a hot tank but I do have a very good jetwash. It was suggested that I could have cleaned out or dislodged some material that was previously blocking some porosity. I will coat with Glyptol tomorrow as it is not difficult to do. Thanks, J.rob
[Re: Triggerfish]
#1852235
06/18/15 11:47 PM
06/18/15 11:47 PM
Posts: 152 usa
smos001
usa
I don't have a good pic of the problem. But, I am telling you this is the problem. I talked to some real experts on this. It's about components. It's about math. You have to measure everything. Something is out of tolerances. Things don't fix a leak because of knurling or smooth polish on the crank surface, grooves in bearings, or the grinding of OEM retainers.Ropes seal don't last and 1960 and 70s era motors did not have rope seals. It's about tolerances.
when we found the measurable problem. We did not even have to test the solution on the stand. We knew we had solved the problem.
Here is one guys solution that started our research I found on another site. He was very helpful. Our solution was similar but using micrometers. His discussion saved my engine (he was a saint!):
Install The rear main lip seal half in the block "flush" with the cap parting line. Install the Crank. If your Lip Seal compression on one side, is less than the other under close inspection with a light, with the Crank in the block, you have a potential for a leaky main. Gently, using a small screwdriver, GENTLY, insert it behind the offending side of poor compression, and "eyeball" the amount required to equal Lip compression "side to side". DO NOT damage the back of the seal with the screwdriver. It doesn't take much. Record the amount required to move the lip seal into equal compression.
Now dis-assemble.
Re-assemble this time, with the Block side Rear Seal lip half protruding approx. 1/4" above the parting line on the offending side. Reverse the same Seal offset installation in the Retainer. Now use the Retainer when installing, to CAPTURE and DRAG the offending poor contact side over into proper seal lip compression, the same amount as you recorded earlier, as you Tighten & Torque the Seal Retianer into place. Silicon up the sides of the Seal Retainer to the Block, deleting the paper inserts. (The paper side inserts probably won't go in anyways due to the Retainer offset installation)
[Re: RAMM]
#1852243
06/19/15 12:07 AM
06/19/15 12:07 AM
Posts: 361 Canada
onig
Canada
WOW, this is a helpful and interesting topic. Can't wait to see what actually worked to fix this.
69 Dart
#1852244
06/19/15 12:07 AM
06/19/15 12:07 AM
Posts: 643 southern conn
1969gtx
southern conn
Had a rear main seal tryed evry thing the fix. In my case had a aluminum tool made that fit the seal and fit in the main bairing put the lower seal cap on then shine a flashlight from the back the seal was to low at the block shimed the up worked grate. will never install a rear seal without testing the fit.
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: smos001]
#1852277
06/19/15 12:38 AM
06/19/15 12:38 AM
RAMM
OK,,, I have been through this hell before. I had my 383 engine built by the best in the business; a professional, 30 year, race engine shop. First run it leaked on the stand. Second seal...leaked on the stand. We pulled it apart 4 times. We checked and sent the crank out to an expert. Perfect crank.
Finally... He tore the engine down to the bare block. Checked everything with a micrometer. After measuring and researching we found that a small percentage of MOPAR block rear main seal retaining threads are drilled off to one side, ever so slightly. It is literately thousands of an inch off. Enough for a small leak according to Felpro.
He eventually used an OEM rear main seal retainer (they have some slop in the side to side placement. Driver to passenger side movement). He shimmed the retainer to one side the distance it needed to go to center the retainer exactly over the crank and to pull the weak side seal over to the crank surface. If you look closely you will see the weak seal side against the crank. also you will need to have the seal slightly off center in the block and retainer to have the retainer grab and pull the weak side over to the crank as you push the retainer to one side.
This is about component machine errors. DO NOT believe in crap like the type of knurling on the crank end, Rope seal fixes, and other non-mathematical crap. It's all about tolerances and measurements. Something has to be measurably wrong. either the crank is off or the retainer/block is off. Don't grind the retainer to make it tighter. Look at the seal as it presses all the way around the crank. I believe he said he used a snap gauge to measure the exact distance it was off from center and that measurement is what he used to push the retainer over.
My engine builder now checks every MOPAR block for this error. He spent months on my engine and cost him time and money that he does not want to go through again.
It was a nightmare. I feel your pain. My engine is now dry and runs strong. Thankyou and yes I have noticed this same thing time and time again. On attempt #4 I influenced the retainer to the side in order to increase contact on the weak side. I am aware of this, I have even taken measurements and shimmed fore and aft. I am all about the tolerances and my instincts say a rubber/PTFE/ whatever seal can take up a lot of misalignment. I am dealing with something dynamic--not static. Thanks for the response though. J.Rob
[Re: 1969gtx]
#1852285
06/19/15 12:43 AM
06/19/15 12:43 AM
RAMM
Had a rear main seal tryed evry thing the fix. In my case had a aluminum tool made that fit the seal and fit in the main bairing put the lower seal cap on then shine a flashlight from the back the seal was to low at the block shimed the up worked grate. will never install a rear seal without testing the fit. This is exactly the next step! I am machining a "stub" that will sit in the main journal and feature the seal journal to eliminate the crank flange. I want to "see" WTF is going on without the damn crank flange in the way. Thanks again! J.Rob
[Re: Monte_Smith]
#1852290
06/19/15 12:46 AM
06/19/15 12:46 AM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
Never seen or heard of a hole, that relieves pressure off the seal.
Ramm, just try the sealing ends 90* apart can't hurt. And like I said, I never glue the seal in the block or retainer. Just place it in there. Place lower half of seal, put crank in, then take upper half of seal and work it around crank until you parting lines at 90*. Then put the retainer in
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1852311
06/19/15 01:05 AM
06/19/15 01:05 AM
rowin4
I have been putting big block mopars together for close to 50 years and never had a leak, except the stud/pan problem mentioned earlier,lucky I guess. I haven't turned a seal 90 degree's but have off set them maybe 3/8" , never has a seal leak. Now watch the next one will pour put like there's no seal in it at all. I think this block is outa wack.
[Re: RAMM]
#1852376
06/19/15 04:16 AM
06/19/15 04:16 AM
Monte_Smith
North Alabama
All this is exactly the reason I say put the seal in the block FIRST, with the ends at 12 and 6 oclock. Then you do whatever you have to do to make the retainer slide over that seal cleanly and freely, with NO influence either direction. With it all dry and no bolts, drop the retainer on and see how it feels and look in the holes to see if it is where it NEEDS to be, not where the bolts, or those idiotic side seals put it. One thing to understand.......the SEAL is what seals the crank. The retainer only holds the seal where it needs to be. With the seal in the block around the crank, the seal IS where it needs to be. Now make the retainer cleanly hold it. This is a piss poor design and always has been, but not unfixable. You need to drill the retainer holes out, drill them, makes no difference. This is NOT a critical piece. It ONLY holds the seal, nothing else. It's just not this hard
Other motors with two piece seals don't have this issue. The reason, is the seal is retained by the rear cap and is always consistent and goes on where it should every time. BBM doesn't have that luxury but is not hard to MAKE it work in a similar way.
If you have never had a BBM rear seal leak.........you simply haven't built enough of them. But since I started doing the above procedure....30 years ago or more........no more leaks
Many also want to "face" the retainer on the bottom, to make sure it sits flush. It MAY need it, but usually not. This generally just makes the seal groove not round any more and changes the crush. If you do that and put the seal where the ends are flush with block and retainer, it will NEVER seal. Its an easy measurement to determine if the retainer NEEDS a shave. Don't do it "just because"
[Re: RAMM]
#1852430
06/19/15 11:06 AM
06/19/15 11:06 AM
RAMM
Studying this closely I think I may have to provide more clearance between the #5 cap rear and the "deflector" on the crank. The black squiggle is where I could machine .057" off. It may do the trick. I really don't think there is any issue with the seal itself. I am leaning towards a severe oil/pressure buildup that NO seal can handle. I'm also starting to think the windage tray should be left out to provide more room between the rear counterweight and the cap. J.Rob Here is how the cap looks after machining. There is about double the room between the back of the cap and the deflector now. I figure it can't hurt. Also I am going to try Monte's method of seal installation. Also reassembling WITHOUT windage tray. Back on the dyno later today. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE!
[Re: smos001]
#1852662
06/19/15 05:38 PM
06/19/15 05:38 PM
RAMM
Ran engine on the dyno for 90 mins. Performed 8 tests. NO LEAKS!!!!! NO LEAKS!!!!! Not a single drop!!
What did I do this time? Three things in conjunction.
1: Machine backside of #5 cap for more oil escape clearance
2: Install new normal black seals as Monte suggested
3: Omit OEM windage tray
While I was skeptical Monte's method would work--apparently it does. My hunch though tells me the windage tray was the real culprit. Don't know for sure at this point. Greatest Friday ever. Thanks for everyone's help and thoughts and possibly prayers. J.Rob
[Re: RAMM]
#1852675
06/19/15 05:55 PM
06/19/15 05:55 PM
Posts: 152 usa
smos001
usa
[Re: RAMM]
#1852690
06/19/15 06:22 PM
06/19/15 06:22 PM
MR_P_BODY
While I was skeptical Monte's method would work--apparently it does. My hunch though tells me the windage tray was the real culprit. Don't know for sure at this point. Greatest Friday ever. Thanks for everyone's help and thoughts and possibly prayers. J.Rob Glad to hear you made some leak free pulls... now I'm wondering what the REAL fix was/is
[Re: RAMM]
#1852694
06/19/15 06:31 PM
06/19/15 06:31 PM
Posts: 361 Canada
onig
Canada
Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal? When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail.
69 Dart
[Re: MR_P_BODY]
#1852697
06/19/15 06:32 PM
06/19/15 06:32 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Congrats on getting that thing sealed up Jesse I know it had to be frustrating Time for a cold one ! Ron
[Re: Monte_Smith]
#1852793
06/19/15 08:53 PM
06/19/15 08:53 PM
RAMM
Glad you fixed it..........but I can pretty much assure you that the windage tray was NOT the problem............LOL!!! Care to make a wager? I still could install tray and test. Seriously though thankyou, Monte. I doubt I would have ever considered arranging seals that way. J.Rob
#1852796
06/19/15 09:03 PM
06/19/15 09:03 PM
RAMM
WINNER! WINNER! CHICKEN DINNER! glad you fixed the problem. one heck of a learning experience. Boy you aren't kidding about the learning experience. I have to give the customer some credit here actually. He is an older gentleman that did not pressure or belittle even once. He and I relayed experiences back and forth over the course of this saga and I could not have asked for a better person to have this happen to. I know that sounds bad, but HE supplied the billet Mancini retainer-which leaked worse than ever. HE supplied 3 oil pan gaskets. He supplied fuel when it wasn't even asked for. HE made countless trips to the shop and he exhausted every one of his resources trying to resolve this problem, all the while remaining in good spirits. J.Rob
[Re: onig]
#1852810
06/19/15 09:30 PM
06/19/15 09:30 PM
RAMM
Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal? When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail. Thankyou Onig, Thankyou so much. I do care. I cannot just give up without knowing the answer. I will share that when I dyno'd it this last Wed and it leaked, I texted the customer right away. He texted back--"What's next?" I responded with "A 20 foot tree limb and a 10 foot rope". There were some dark moments to be sure. To answer your question: The customer ate it in terms of some parts, and time and anguish. I ate it in the same fashion. I cannot charge someone that has entrusted me because of my expertise in a given area and I fail to deliver. This was in NO way shape or form the customers fault. I am just glad to have solved the problem. 12 pan gaskets, 3 intake valley pan gaskets, 1 set of rings and 7 rear main seals later.. Lucky for you member MattW here and I are about to embark on G3 HEMI development. Thanks J.Rob
[Re: onig]
#1852821
06/19/15 09:48 PM
06/19/15 09:48 PM
RAMM
So the seal is installed 90* from normal? That is correct. The seals are test installed in a pic above. J.Rob
[Re: firefighter3931]
#1852838
06/19/15 10:14 PM
06/19/15 10:14 PM
RAMM
Congrats on getting that thing sealed up Jesse I know it had to be frustrating Time for a cold one ! Ron Thankyou Ron! I am currently about 3 Bud tallboys in. p.s. How did your 440 Stealth headed project turn out? J.Rob
[Re: RAMM]
#1852886
06/19/15 11:26 PM
06/19/15 11:26 PM
Posts: 361 Canada
onig
Canada
My son and I were at MattW's place last year on his Indy head transaction. Looking forward to the Gen 3 development.
69 Dart
[Re: tman]
#1852916
06/19/15 11:49 PM
06/19/15 11:49 PM
RAMM
Curious. Which seal retainer did you end up using? Reconditioned stock one. J.Rob
[Re: onig]
#1852919
06/19/15 11:51 PM
06/19/15 11:51 PM
RAMM
My son and I were at MattW's place last year on his Indy head transaction. Looking forward to the Gen 3 development. Great! Matt and I have known and grown with each other for about 13 or so years now. We have big things in the works concerning G3's. J.Rob
[Re: RAMM]
#1853021
06/20/15 02:48 AM
06/20/15 02:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
do you have a rope seal you can install?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1853034
06/20/15 04:14 AM
06/20/15 04:14 AM
Monte_Smith
North Alabama
do you have a rope seal you can install? I think you are a little late to the party brother...........LOL!!!
[Re: RAMM]
#1853059
06/20/15 09:25 AM
06/20/15 09:25 AM
gregsdart
Congrats!! The first part of this thread was painful to read, in part because I've had a similar problem, many attempts to fix, and got it down to a very limited drip, but never perfect. Next time the pan comes off, it will get fixed like you described.
[Re: moparx]
#1853066
06/20/15 09:42 AM
06/20/15 09:42 AM
RAMM
when the seal ends are at 6 & 12, and the retainer cap fits correctly dry, tighten the retainer bolts then fill side cavities with rtv. correct ? That is correct. J.Rob
[Re: RAMM]
#1853108
06/20/15 11:25 AM
06/20/15 11:25 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Great job on the fix. This post should be saved in the archives.
[Re: moparx]
#1853249
06/20/15 04:01 PM
06/20/15 04:01 PM
Monte_Smith
North Alabama
when the seal ends are at 6 & 12, and the retainer cap fits correctly dry, tighten the retainer bolts then fill side cavities with rtv. correct ? When "dry fitting" everything, you will be able to "feel" as well as see when it fits right, with no influence on the seal. Like I said, you will probably have to drill the retainer holes bigger, but that doesn't matter. Once the dry fit is good, the retainer will continually return to the "right" place when you drop it in. So for final install, put a little RTV on the bottom and you can also fill the side channels as well..........then drop it in, bolt it down. I am actually surprised this seems to be a "new" method for so many. This has been such a problem for BBM over the years, I just assumed everybody knew this already..........LOL!!! Seems every builder knows you rotate the seal ends on Chevy's and don't glue them in. I just applied the same theory to the Mopar and assumed everyone else did the same.......
[Re: RAMM]
#1853259
06/20/15 04:25 PM
06/20/15 04:25 PM
firefighter3931
Ontario,Canada
Congrats on getting that thing sealed up Jesse I know it had to be frustrating Time for a cold one ! Ron Thankyou Ron! I am currently about 3 Bud tallboys in. p.s. How did your 440 Stealth headed project turn out? J.Rob Hi Jesse, Denis is very happy with the attention to detail on your work and looking forward to running his new RAMM machined Stealth's. They're bolted on but he ran into some pushrod clearance issues so I brought him my die grinder and a carbide to open up the pushrod holes. He's running Crane ductile iron 1.5 rockers with 3/8 pushrods. A 5/16 pushrod would have been no problemo I'll keep you up to date on our progress Ron
#1853270
06/20/15 04:44 PM
06/20/15 04:44 PM
crabman173
crabman173
I have been having to do lots of extra grinding on Sidewinders for 3/8ths just depending on what rocker is used so I went to 5/16ths and it makes life EASIER--Smith Brothers has assured me that at 9 inch length range ( typical 440) that a 5/16th .080 wall is good to 700 open so more than covers any street application --they make .120 wall for folks that can't sleep at night--I would never do it in race application with big roller but that is not what they are all about anyway
[Re: ]
#1853273
06/20/15 04:55 PM
06/20/15 04:55 PM
crabman173
crabman173
I am happy you got this fixed--I am going to try it on my next build--Thing is I just can't get past the fact that we built way over 100 BB Mopars over the years and NEVER a leak then all of a sudden last few years whammo! I believe that it is because of inferior offshore produced seals--I put so many together so many ways with every kind of block, crank etc over the years with the good old Fel Pro then they changed that darn seal! We ( me , Todd M and 2 other well known builders in NC) swapped to the Superformance red seal--All 4 of us went a long while with NO leaks--then..He swapped to a black seal ( I would guess Victor) and said NO DIFF--kept on charging big $$ for it --OK, I don't care as long as it works then...all 4 of us have had leak issues again! I am NOT happy with that outfit! I have ordered all 3 part numbers of FelPro, a Mr Gasket, and Victor rep is sending samples to our shop next week, I also have a seal from a fresh new Sealed Power gasket set and have been looking for any older stock seals--I plan to lay them all out, study them, measure them and see what is going on. I ask every engine shop manager I see what they do and keep notes--I was surprised last week when big reman shop told me about a string of trouble they had and when it was finally fixed they found that the lube a white lithium grease type they had been using was the culprit--Fel Pro said wrong lube is #1 problem so what the heck is the correct lube??? I now use OIL only--had always just used assem lube like the red or some STP/assem lube mix I keep in an oil can etc I have never used a grease type product. I really appreciate the contributions to this thread by the many skilled dedicated builders but feel like there is STILL more than meets the eye here and that seal quality or lack of is a big part of it-- Like everything else in this USA --sourced from cheapo place so that corps make $$ NO care at all about us in the field Just my two cents
[Re: tman]
#1853376
06/20/15 08:11 PM
06/20/15 08:11 PM
RAMM
Ramm, what exact rear main seal did you end up using? I know you said, "Black one." Just used the ones that come in the FelPro RACE 2716 set. Nothing special and they are made by National Seal& Bearing. It was a shame to waste the FelPro "good" red ones #2947 that the customer supplied me. I have mentally designed and have part #'s for a speedi-sleeve and 1 piece seal using a bolt on 2 piece billet aluminum housing. It would only work with aftermarket fully round crank flanges but I was getting desperate--lol. J.Rob
[Re: smos001]
#1853381
06/20/15 08:15 PM
06/20/15 08:15 PM
RAMM
My engine builder order every seal imaginable. They all looked the same. Must be the same mold now for every manufacturer. If you find a different variant,pass it on. They are all the same, save for the material. I am only referencing the RED one here. Big deal--they may hold up better in a severe high heat situation but then you have other problems. Believe me I was fantasizing about machining another groove in the block and machining a dedicated retainer to double up the seals at one point. Scary thing is I was this close to doing it--'cuz I can. J.Rob
[Re: onig]
#1853785
06/21/15 02:14 PM
06/21/15 02:14 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal? When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail. I've known Jesse for some time now and I can say this. He is an excellent machinist. The man can fab and hold tolerances. He can and has rebuilt just about everything that runs. Oh and he is a Moparts nut. Lol Your build would be in excellent hands. Matt
[Re: rowin4]
#1855660
06/24/15 12:26 AM
06/24/15 12:26 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
You don't happen to mean like this do you? Engine in the car and as I was torquing retainer pan studs,,,,instead of usual bolts,,,,felt a rapid loss of torque as though had stripped out aluminum retainer thread.
Milodon RR pan, ARP studs for main caps.
A bit of grinding with Dremel and all was well.
As an aside for OP, your rear pan bolts that go into retainer are required to be shorter than the other 18 pan bolts if you are using the slightly longer than stock pan bolts such as supplied in after market kits such as Mr. Gasket. They send you 20 bolts all the same length all slightly longer than stock,,,,,used at retainer they will bottom out before pan is tightly sealed giving appearance of a rear main leak.
1974 Motor Repair manual discusses this in section on replacing big block mopar oil pan. There also is a mopar factory directive that discusses this.
With engine in car this is not obvious, but with engine mounted on an engine stand at dyno this may not fool you. OP did say he had examined closely with a flashlight with engine running and that indication is that his issue is not pan leak however. This is how I discovered my problem with engine running in car. Mr. Gasket pan bolts bottoming were bottoming in retainer before pan was properly cinched up. Hence now, my use of studs.
Likely with OP as he has we'll investigated, not his issue,,,just a heads up for others who may be experiencing mysterious rear main leaks or what appear to be so.
I have posted a couple of other threads on this forum discussing my own journey and twilight zone adventure with confounding rear main oil leaks. .
Hopefully the peanut gallery will contain themselves and refrain from sniping at this post,,,,a private request that a couple of forum gentlemen might understand.
[Re: Monte_Smith]
#1856815
06/25/15 05:56 PM
06/25/15 05:56 PM
Posts: 447 NJ
JCCuda
NJ
when the seal ends are at 6 & 12, and the retainer cap fits correctly dry, tighten the retainer bolts then fill side cavities with rtv. correct ? When "dry fitting" everything, you will be able to "feel" as well as see when it fits right, with no influence on the seal. Like I said, you will probably have to drill the retainer holes bigger, but that doesn't matter. Once the dry fit is good, the retainer will continually return to the "right" place when you drop it in. So for final install, put a little RTV on the bottom and you can also fill the side channels as well..........then drop it in, bolt it down. I am actually surprised this seems to be a "new" method for so many. This has been such a problem for BBM over the years, I just assumed everybody knew this already..........LOL!!! Seems every builder knows you rotate the seal ends on Chevy's and don't glue them in. I just applied the same theory to the Mopar and assumed everyone else did the same....... Not trying to beat a dead horse but....Just so I'm clear, you don't use the side seals at all with this method? Only RTV? And by the way Thank You to All for this post it is very timely for me.
[Re: ]
#1857149
06/25/15 11:38 PM
06/25/15 11:38 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
We ( me , Todd M and 2 other well known builders in NC) swapped to the Superformance red seal--All 4 of us went a long while with NO leaks--then..He swapped to a black seal ( I would guess Victor) and said NO DIFF--kept on charging big $$ for it --OK, I don't care as long as it works then...all 4 of us have had leak issues again! I am NOT happy with that outfit! crabman173, before you go attack my products, character, business and livelihood on an open web forum get your facts right! I never relayed ANY facts directly to you. I did not “swap” to a black seal. Both the “black” Polyacrylate and the “orange” Viton seals have been discontinued. We have depleted our inventory of the Viton seal and have a limited inventory of the Polyacrylate seals available at this time. No it is NOT a Victor seal. The ONLY difference between the “black” Polyacrylate seal and the “orange” Viton seal we supply is the rubber compound, PERIOD! So far as your claim to us still charging BIG $$ for the “black” Polyacrylate seal is a flat out lie. Without quoting prices I can honestly state our Polyacrylate seal sells for 40% LESS than it’s Viton counterpart. You do NOT purchase directly from Superformance Products therefore what you pay is between you and your supplier. I however call BS on your claim. You’re not happy with my outfit? Well I’m not too thrilled with your comments.
Same Chrysler OEM number
[Re: JCCuda]
#1857153
06/25/15 11:42 PM
06/25/15 11:42 PM
Monte_Smith
North Alabama
Correct........"driving" those side seals in can move the retainer........because as you know, you can't fully tighten the retainer and THEN get those seals in, you have to do it all together. So after it "fits" right, fill the channels with RTV, just a bit on the bottom...NOT a lot and drop the retainer in, tighten it down, clean off excess. Usually at this point, I will take a tube of RTV and use the white tube that comes with them, with just a bit cut off the end to make a small bead. Then put a small bead down each side and across the bottom, to make SURE there is no opening in the RTV seal
Monte
[Re: RAMM]
#1857268
06/26/15 09:04 AM
06/26/15 09:04 AM
crabman173
crabman173
Leaks cause frustration Frustration clouds judgement Public apology applied here and now Hope you will accept
Common factor of leaks with blacks, none with the other across number of shops / same time line-- is also a fact---frustration still weighs heavy
Develop a dependable new seal USA made that works and the world will beat a path to your door brother and price will not be an issue at all .
[Re: RAMM]
#2471319
03/24/18 01:01 PM
03/24/18 01:01 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
So three years later is there still a better seal in the orange versus black color ?
My newly rebuilt 432 Stroker 440 Source has a small leak and its definetly in this area
Valve Covers and Oil Pressure Sender perfect
I am still debating on if it was the actual seal , or those side o rings in the Mancini Retainer
It wasn't leaking prior to the rebuild this past fall , I offset the black fel pro seal at 6 and 12 and used black rtv on those side o rings on the Mancini Retainer for a few years and it was spotless
Only difference this time around is I don't know what black seal my engine builder used and the 440 Source crank is polished smooth versus the old factory crank that I took apart that was knurled in that seal area
Block was hot tanked prior to rebuild also , and I had a snap on borescope inbetween the engine and transmission double checking the cam plugs etc after engine was shut down looking for leaks
Had my engine builder offset the seals at 6 and 12 , but he didn't use any rtv on those side o rings
Also on Hughes website they talk about Locktite 518 gluing the seal halves together where they contact
Just debating on these side o rings , black rtv or this anaerobic 518 gasket maker and the actual best seal before I attempt it again this weekend
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: RAMM]
#2471357
03/24/18 02:45 PM
03/24/18 02:45 PM
bee1971
Sobieski Wi
To late
Already ripped apart and everything cleaned up
Was just debating on what seal , if anything has changed in these seal manufactures as of late
And these black o ring side seals if I should still use or just rtv or anaerobic gasket maker
[Re: bee1971]
#2471433
03/24/18 06:18 PM
03/24/18 06:18 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I really think Monte was correct with his diagnosis of the seal retainer not fitting the block perfectly. This is something that MUST be perfect or is will not seal no matter what seal you have installed. Enlarging the holes will let the seal move to where it wants to be in relation to the crank journal center line. This will be the way I do it next time if I ever have my engine apart again. It has a very slight leak there right now but nothing I'm worried about because it's maybe a teaspoon a month on the floor. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: bee1971]
#2471669
03/25/18 04:43 AM
03/25/18 04:43 AM
Posts: 43,185 Bend,OR USA
Cab_Burge
Are you using stock main cap bolts or studs now? I use a adhesive silicone(it must have adhesive on the label ) to stop leaks on the main seals on BB by filling in the sides of the cap between the block and seal holder, both sides facing the flex plate, flywheel and also on the bottom, top of the seal holder, touching the block I use a flat thin putty knife or small flat thin blade screw driver to force it into the hollow spots all the way all the way around the seal holder, take your time to get it correct I also use a tiny dab on the seal half ends where they butt up against each other, I don't stagger them either I use a little tiny bit on the cap to the block surface also, not a bunch I can't remember the last time I had a rear main seal leak, probably over 40 motors ago I can't say the same thing about the rear cam plug I seal them up now also with the adhesive silicone after they are installed all the way into the stop groove step IHTHs
[Re: Greentween]
#2509256
06/16/18 10:18 AM
06/16/18 10:18 AM
bee1971
Sobieski Wi
Hey bee1971, what was outcome with your seal and retainer?
I was doing same, and bought Mancini retainer kit with the 4 o-ring side seals. Dry fitting it I checked the gap between retainer o-rings and block. The o-rings dont even touch the block. .003" feeler gauge slides in between without any drag. The o-ring grooves seem too deep to me.
I think I will try directions as per post above - to fill the side seal with RTV. I don't know if I can fill that small o-ring groove all way toward cam from the bottom.
Also, Doing this with engine in the car,I don't see anyway to RTV the retainer once it is assembled. Maybe need to slide the trans back?? Orange/Brown Fel Pro Viton Seal Permatex Black Rtv down the sides of those O-rings Still used the O-rings , but also black rtv Yes on those O-rings - The design or concept looks great but the O-ring itself needs to change , as in a little wider/thicker better material - I couldn't come up with anything else to use but they just don't fit properly in those grooves , way to loose ? I knew where the retainer needed to bee seated/fitted prior to the installation as the marks where still there from when I mocked it up before the crank got dropped in Seal halves at 6 - 12 Anyways its definitely not a seal issue , but rather those side O-rings and there fit seems to bee the culprit So far so good
[Re: cdp]
#2509266
06/16/18 10:34 AM
06/16/18 10:34 AM
bee1971
Sobieski Wi
Except that it goes against just about every post or thread on the internet or engine builders advice on using any type of silicone on the seal halves or seals So ? Does it work is the question of the day The studs for sliding the retainer in place Mancini Racing supplies with there billet retainer - Definitely yes on those , for dry mock up and final installation
[Re: RAMM]
#2509274
06/16/18 11:40 AM
06/16/18 11:40 AM
crabman173
crabman173
The rope seal offered by BEST GASKET is a black carbon looking kit with very specific instructions about install--IT WORKS without the drag of older real rope seals--This part works to cure the leaky rear seal blues
[Re: RAMM]
#2509277
06/16/18 11:57 AM
06/16/18 11:57 AM
Posts: 1,131 Home of the Bluegrass
MoparJunkie
Agreed.... of the couple rear main seal leak issues I’ve had, from what I’ve found are two issues. Most seals are sh@t, and the side seals push the retainer off center(well, if the retainers are machined properly)! I will only use the orange felpro seals and RTV on the sides of the retainer only. This procedure has cured both of my leaks and they are still dry.... I did index the seal at 6-12 on the 383, however on the Hemi I put them as designed at 3-9. Both ways worked so.... you be the judge which works better!
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: RAMM]
#2510349
06/19/18 12:37 PM
06/19/18 12:37 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m not sure of the exact timeline, but I think I started having intermittent rear seal leak issues when the gasket kits stopped using the hard white-ish side seals for the retainer. Those were the ones you dipped in mineral spirits, and just slipped them into place.... then after some time they would swell up in place to fill the void, after the seal cap was already in place and torqued down.
Once those went away, that’s when the problems started to pop up for me.
This thread is a good tutorial for someone who’s had a chronic leaker.
[Re: RAMM]
#2510615
06/20/18 12:37 AM
06/20/18 12:37 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have just about finished fitting the engine back into my car after a major engine bay repaint and big stroker rebuild, Im more worried about a rear main leak than if the engine build is good.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: fast68plymouth]
#2510618
06/20/18 12:45 AM
06/20/18 12:45 AM
rowin4
This thread is a good tutorial for someone who’s had a chronic leaker. I never had a leak with the as you say the whitish type seals , then they came out with fuzzy pipe cleaner side seals that you just kept pushing in the sealant . Now the plastic wedge type, yep , drip , drip , drip
[Re: 71birdJ68]
#2511313
06/21/18 01:44 PM
06/21/18 01:44 PM
Posts: 3,076 Michigan
A727Tflite
P I didn't read all of the posts, but I have a question. Why doesn't someone make a seal retainer so that a one piece seal can be used. After the responses, I'll give my logic. I would be interested in seeing how you would get the seal over the crank flange.
[Re: A727Tflite]
#2511324
06/21/18 02:05 PM
06/21/18 02:05 PM
Posts: 4,453 Morristown Tn.
71birdJ68
Morristown Tn.
Ok, I'll explain. We do it on airplane piston engines. Keep in mind that the propeller flange is way bigger than auto crank flanges. We remove the spring in the backside lip of the seal, then heat the seal up a little with a hairdryer to make it more pliable. There is a tool that resembles a shoe horn that lets us stretch, and walk the seal around the flange. After it has regained its size, and shape, we reinstall the spring, and push press it home using contact cement to seal, and hold it in place. On some very large flanges for constant speed props, we slice it, the install it with that slice at the top position. I don't see why this type of seal, and retainer couldn't be developed for car engines.
[Re: A727Tflite]
#2511410
06/21/18 05:10 PM
06/21/18 05:10 PM
MoparJunkie
All the hype about clocking the seal halves doesn’t hold any water as the engine plants never did this nor did they use any sealing compound. I don’t recall any epidemic of seal leaks back in the day either.
The only thing I see "clocking" the seals does is it helps center the retainer around the crank/seal, thus not letting the side seals dictate where the retainer rests so to speak....just my two cents. As I stated earlier I've tried both ways with success, but I'm giving some merit to a better seal being used.
[Re: A727Tflite]
#2511412
06/21/18 05:13 PM
06/21/18 05:13 PM
MoparJunkie
I think what is happening is people using worn out parts, improper installation techniques and/or sequences, maybe an occasional bad or wrong part and not being observant on the initial engine mock up and build.
Too many top name engine builders experiencing this epidemic for that theory to hold up....Anyone from Dwayne Porter to Ray Barton, I've talked to many about the issues.... Many theories, but no definitive answers.
[Re: RAMM]
#2511415
06/21/18 05:17 PM
06/21/18 05:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Every bigblock rear main seal leak I’ve encountered was one of two things... either no sealant between the block to retainer mating surface (most common),or interference from main cap/ stud causing misaligned retainer. People are always fed up on this repair. I usually get the “I don’t care what it costs” rant. They have missed simple steps several times before I see it.
[Re: RAMM]
#2511445
06/21/18 06:46 PM
06/21/18 06:46 PM
MoparJunkie
As I said talk to the main players with engine building you’ll see.... it’s the front runner of topics!
[Re: RAMM]
#2511472
06/21/18 08:22 PM
06/21/18 08:22 PM
rowin4
Well if you look at the end of the crank seal you will see why it leaks. The ends of the seals are not flat at all , it looks like they just chop the end off as it comes out of the mold leaving a small round stub.Trying to seal that is nearly impossible .
[Re: MoparJunkie]
#2511481
06/21/18 08:49 PM
06/21/18 08:49 PM
bee1971
Sobieski Wi
The only thing I see "clocking" the seals does is it helps center the retainer around the crank/seal, thus not letting the side seals dictate where the retainer rests so to speak....just my two cents. As I stated earlier I've tried both ways with success, but I'm giving some merit to a better seal being used. X2
[Re: TRENDZ]
#2511642
06/22/18 09:52 AM
06/22/18 09:52 AM
Posts: 1,051 The Great White North
RAMM
Every bigblock rear main seal leak I’ve encountered was one of two things... either no sealant between the block to retainer mating surface (most common),or interference from main cap/ stud causing misaligned retainer. People are always fed up on this repair. I usually get the “I don’t care what it costs” rant. They have missed simple steps several times before I see it. It's been a little over 3 years now and the customer and I have been in touch and no leaks. You must not have read the entire thread Trendz. I still experience some anxiety when I assemble a B/RB , but am extremely happy to report I have not had one oil leak when using the 12 and 6 method in conjunction with enlarging the retainer holes. Thankyou again everyone and Monte RIP. J.Rob
[Re: RAMM]
#2512804
06/24/18 11:24 PM
06/24/18 11:24 PM
ozymaxwedge
Australia
Well it got me ,,, been working real hard on this car and finally drove it yesterday, after about 5 miles the smoke off the exhaust started. Seriously not felling like pulling this engine back out but dont think I can get the pan off while its in there. For the life of me I cant remember putting sealant on the retainer mating surface, it's probably it. F#*^ it.
[Re: ozymaxwedge]
#2516664
07/02/18 11:29 PM
07/02/18 11:29 PM
Posts: 211 ILL
Greentween
ILL
I'm posting how I did the rear main side seals. I have engine in the car. Cannot fill the side seals from the outside of the block so this is how I did it. Equipment: a) Mancini retainer with the o-ring side seals. DID NOT USE THE ORINGS. My OEM retainer was damaged. Oil pan screws poked thru due to using wrong screws. b)5ml syringe - 14ga blunt tip needle 4" long and 1.5" long. Amazon. c)Permatex ultra grey. I dont know if there is better RTV. I checked clear RTV and utra grey, and grey seemed tiny bit thinner. Need to be able to get it thru the 4" needle.I did shorten the 4" needle about an inch. d) Made a handle for syringe from a house light fixture attachment bracket. e) permatex 518 - for gluing the main seal ends.
1/17/18 Update: Thinking about this after doing this, I found 3mm needle on amazon. Look up "sauce injection syringe". That would flow the silicone much easier. I would still hook the needle to 5ml syringe.
[Re: Greentween]
#2516670
07/02/18 11:37 PM
07/02/18 11:37 PM
Posts: 211 ILL
Greentween
ILL
I first glued the ends of the seal together with a dab of the 518 on each end and put retainer in place (dry fit retainer with seal ends 6 and 12 oclock) by letting retainer self locate over the seal. let is dry overnight With retainer in place and now is good time to confirm the 2 oil pan threaded humps will not hit 5 main cap. You may need to fix those 2 "humps" for more clearance later.
Note: picture is out of sequence. Used this pictuer to show "humps" which may hit #5 main cap.
[Re: Greentween]
#2516681
07/02/18 11:49 PM
07/02/18 11:49 PM
Posts: 211 ILL
Greentween
ILL
Next day checked the seal ends they were glued together. Reassembled retainer letting it self locate. Then used syringe with 4" blunt tip needle to inject Ultra grey down into upper portion of Oring grooves. It was a [censored] to get the RTV to come out the needle end which is why needed to use handle on the syringe. Once i see RTV ooze out watching near #5 cap, then I know it is filled. I filled the top half inch with long needle then switched to short needle for the lower part of the groove. Short needle RTV comes out way easier.
In picture you can see grey RTV between block and aluminum retainer, filled by syringe thru o ring groove from below.
[Re: Greentween]
#2516691
07/03/18 12:04 AM
07/03/18 12:04 AM
Posts: 211 ILL
Greentween
ILL
I have not checked for leaks yet. I Will post good or bad once I do that. Should be able to do that soon.
If I were to do again I would use 3ml syringe instead of 5ml. That may be easier to get RTV thru the 3" needle with.
Update 7/17/18 No leaks
[Re: RAMM]
#2516693
07/03/18 12:06 AM
07/03/18 12:06 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Did you say dry fit? or dry fit the very ends where you glued? A dry fit will wipe out the seal on start up. Must be clear, others a watching.
[Re: ozymaxwedge]
#2516768
07/03/18 05:42 AM
07/03/18 05:42 AM
ozymaxwedge
Australia
Well it got me ,,, been working real hard on this car and finally drove it yesterday, after about 5 miles the smoke off the exhaust started. Seriously not felling like pulling this engine back out but dont think I can get the pan off while its in there. For the life of me I cant remember putting sealant on the retainer mating surface, it's probably it. F#*^ it. Want a giggle ?? After pulling the box and finding a dry rear main I put it back in, for the next 5 days I replaced the -12 line, purchased and fitted new AN fittings only to wake up and think, "the f*ckin dip stick hole" . I have an aluminum pan that has the tube welded to the other side, I had forgotten that we last ran this engine with a different pan. Sooooo all my oil was coming up through the open dip stick hole in the block. IDIOT
[Re: ozymaxwedge]
#2516877
07/03/18 02:06 PM
07/03/18 02:06 PM
Cab_Burge
Well it got me ,,, been working real hard on this car and finally drove it yesterday, after about 5 miles the smoke off the exhaust started. Seriously not felling like pulling this engine back out but dont think I can get the pan off while its in there. For the life of me I cant remember putting sealant on the retainer mating surface, it's probably it. F#*^ it. Want a giggle ?? After pulling the box and finding a dry rear main I put it back in, for the next 5 days I replaced the -12 line, purchased and fitted new AN fittings only to wake up and think, "the f*ckin dip stick hole" . I have an aluminum pan that has the tube welded to the other side, I had forgotten that we last ran this engine with a different pan. Sooooo all my oil was coming up through the open dip stick hole in the block. IDIOT Welcome to the club that Murphy messes with If you don't error now and then how you going to learn Congrats on the find and sharing it with us
[Re: ccdave]
#2567133
10/21/18 12:37 AM
10/21/18 12:37 AM
bee1971
Sobieski Wi
Offsetting the seal does little to nothing to prevent the seal from leaking. I’ve built at least 8 bb Mopars over the past 5 years with no offset on the seal. Zero leaks. It’s all about the alignment of the upper and lower half’s of the seal. And offsetting the upper and lower half s helps with the alignment of the aluminum retainer itself I got to play with this when I built my motor last winter Aligning the seals flush with the block , crankshaft out , and then marking the retainer surface and block with a sharpie when snugging up the retainer and seeing the alignment of the seals with the crankshaft installed and out Then tried offsetting the seal halves at 12 and 6 , installing the retainer again , and the retainer was in perfect alignment with those sharpie marks Personally I think a lot of these leaks has to do with the side seals or retainer
[Re: bee1971]
#2567265
10/21/18 01:00 PM
10/21/18 01:00 PM
Posts: 1,987 Apollo, PA.
B1MAXX
Apollo, PA.
I just went through this. This is what fixed it:
1.Found interference with windage tray and top of stud , drilled windage tray to allow stud to "pass trough"
2. found interference with the little 12-point nut and seal retainer, 1/2 moon-ed the retainer in the nut area for clearance.
3. clocked-seal 90 degrees.
This was a fresh engine that was run 3-4 times pulled out, sealed up, pressurized and leak checked with soapy water and held 25 psi of crankcase pressure out of the car with no visible leaks at the gasket or seal, however leaked like a sive while running. Being able to examine the pan gasket under pressure I am confident that this was not a gasket issue. My summary would be that to make sure that the retainer can float without interference , then clock seal 90 degrees so that it alignment is guaranteed, fill sides with a good sealer sealer (I have always just used sealer on the sides). I have built many bb mopars, stock rebuilds, stud applications in stock blocks, and aftermarket block builds, this was my first leaker.
