Page 4 of 8 1 2 3 4 5 6 7 8
Re: 440 Rear Main Seal Leak--Almost Suicidal!! (Long) [Re: RAMM] #1852460
06/19/15 12:16 PM
06/19/15 12:16 PM
usa
smos001 Offline
smos001  Offline
usa
There is a guy who sells a one piece rear main seal. You put one cut in it.
Not sure if it will help. I still think you have to find the errors first.
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: smos001] #1852662
06/19/15 05:38 PM
06/19/15 05:38 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Ran engine on the dyno for 90 mins. Performed 8 tests. NO LEAKS!!!!! NO LEAKS!!!!! Not a single drop!!
What did I do this time? Three things in conjunction.
1: Machine backside of #5 cap for more oil escape clearance
2: Install new normal black seals as Monte suggested
3: Omit OEM windage tray
While I was skeptical Monte's method would work--apparently it does. My hunch though tells me the windage tray was the real culprit. Don't know for sure at this point. Greatest Friday ever. Thanks for everyone's help and thoughts and possibly prayers. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852666
06/19/15 05:44 PM
06/19/15 05:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Glad you fixed it..........but I can pretty much assure you that the windage tray was NOT the problem............LOL!!!
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852675
06/19/15 05:55 PM
06/19/15 05:55 PM
usa
smos001 Offline
smos001  Offline
usa
Congrats!
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852686
06/19/15 06:15 PM
06/19/15 06:15 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
WINNER! WINNER! CHICKEN DINNER! glad you fixed the problem. one heck of a learning experience.
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852690
06/19/15 06:22 PM
06/19/15 06:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to hear you made some leak free pulls... now I'm wondering
what the REAL fix was/is
wave
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852694
06/19/15 06:31 PM
06/19/15 06:31 PM
Canada
onig Offline
onig  Offline
Canada
Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal?
When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail.
69 Dart
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: MR_P_BODY] #1852697
06/19/15 06:32 PM
06/19/15 06:32 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Congrats on getting that thing sealed up Jesse thumbs
I know it had to be frustrating mad
Time for a cold one ! beer
Ron
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: Monte_Smith] #1852793
06/19/15 08:53 PM
06/19/15 08:53 PM
RAMM Offline OP
RAMM  Offline OP
Care to make a wager? I still could install tray and test. Seriously though thankyou, Monte. I doubt I would have ever considered arranging seals that way. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: 9secondsatellite] #1852796
06/19/15 09:03 PM
06/19/15 09:03 PM
RAMM Offline OP
RAMM  Offline OP
Boy you aren't kidding about the learning experience. I have to give the customer some credit here actually. He is an older gentleman that did not pressure or belittle even once. He and I relayed experiences back and forth over the course of this saga and I could not have asked for a better person to have this happen to. I know that sounds bad, but HE supplied the billet Mancini retainer-which leaked worse than ever. HE supplied 3 oil pan gaskets. He supplied fuel when it wasn't even asked for. HE made countless trips to the shop and he exhausted every one of his resources trying to resolve this problem, all the while remaining in good spirits. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: onig] #1852810
06/19/15 09:30 PM
06/19/15 09:30 PM
RAMM Offline OP
RAMM  Offline OP
Thankyou Onig,
Thankyou so much. I do care. I cannot just give up without knowing the answer. I will share that when I dyno'd it this last Wed and it leaked, I texted the customer right away. He texted back--"What's next?" I responded with "A 20 foot tree limb and a 10 foot rope". There were some dark moments to be sure.
To answer your question: The customer ate it in terms of some parts, and time and anguish. I ate it in the same fashion. I cannot charge someone that has entrusted me because of my expertise in a given area and I fail to deliver. This was in NO way shape or form the customers fault. I am just glad to have solved the problem. 12 pan gaskets, 3 intake valley pan gaskets, 1 set of rings and 7 rear main seals later..
Lucky for you member MattW here and I are about to embark on G3 HEMI development. Thanks J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: onig] #1852821
06/19/15 09:48 PM
06/19/15 09:48 PM
RAMM Offline OP
RAMM  Offline OP
That is correct. The seals are test installed in a pic above. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: firefighter3931] #1852838
06/19/15 10:14 PM
06/19/15 10:14 PM
RAMM Offline OP
RAMM  Offline OP
Ron
Thankyou Ron! I am currently about 3 Bud tallboys in.
p.s. How did your 440 Stealth headed project turn out? J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852869
06/19/15 11:06 PM
06/19/15 11:06 PM
WA
tman Online content
tman  Online Content
WA
Curious. Which seal retainer did you end up using?
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1852886
06/19/15 11:26 PM
06/19/15 11:26 PM
Canada
onig Offline
onig  Offline
Canada
My son and I were at MattW's place last year on his Indy head transaction. Looking forward to the Gen 3 development.
69 Dart
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: tman] #1852916
06/19/15 11:49 PM
06/19/15 11:49 PM
RAMM Offline OP
RAMM  Offline OP
Reconditioned stock one. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: onig] #1852919
06/19/15 11:51 PM
06/19/15 11:51 PM
RAMM Offline OP
RAMM  Offline OP
Great! Matt and I have known and grown with each other for about 13 or so years now. We have big things in the works concerning G3's. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1853001
06/20/15 01:50 AM
06/20/15 01:50 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Just curious which windage tray WAS used - some the louvers aren't real tall and oil can pool up ?
I guess the fix was add more or open the louvers wider to improve drain back.
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #1853006
06/20/15 02:00 AM
06/20/15 02:00 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
you mentioned the glyptol did that have any effect ?
Re: 440 Rear Main Seal Leak--Almost Suicidal!! (Long) [Re: RAMM] #1853021
06/20/15 02:48 AM
06/20/15 02:48 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
do you have a rope seal you can install?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
