1969 door glass trim install #1850845
06/17/15 12:41 AM
06/17/15 12:41 AM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
What is the correct procedure to reinstall this stainless trim piece on to the glass?
Is a sealant or butyl needed?
Re: 1969 door glass trim install [Re: B5496RR] #1850946
06/17/15 08:55 AM
06/17/15 08:55 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
It is called glass setting tape. My car was a post, so I did not have this piece. I did redo the vent windows at the front of the door though. It is the same material.
https://www.bobdrake.com/ItemForm.aspx?Item=B-37193-B
Wrap the tape around the glass. Firmly install the glass, if the tape is the right size it will take a bit of push to get it in. Be careful, you are working with tempered glass. Then trim the extra material, if any, and you are good to go.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 1969 door glass trim install [Re: Big D A12] #1851208
06/17/15 05:36 PM
06/17/15 05:36 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
Great, this is very helpful!
Thank you!
