Np 435 to 518 #1787189
03/24/15 09:01 AM
03/24/15 09:01 AM
Sunfish Offline OP
Sunfish  Offline OP
Anyone swapped in an automatic overdrive tranny in place of the 435 granny?
Any clearance issues? It's a 73 d200.
Pulled a sterling column and linkage from a 77 automatic, and a crossmember and driveshaft from a 89 250.
Re: Np 435 to 518 [Re: Sunfish] #1849948
06/15/15 09:26 PM
06/15/15 09:26 PM
Jacksonville, AR
dmckeehan Offline
dmckeehan  Offline
Jacksonville, AR
I swapped a 518 in place of my 435. It was in a 1985 Crew cab 4x4. Had to modify the tranny mount, shorten rear driveshaft and lengthen front drive shaft. I used a cable operated shifter on mine. no clearance issues at all. other than modifying a factory transmission mount from a 97 model truck, it was all bolt in
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205
2002 3500 extended cab, 4x4, Cummins and 6 speed
1997 Ram 2500 5.9 with 35 Boggers - Mud Racer
1993 Dakota 4x4, Dana 60's front and rear - work in progress
1992 Dakota 2wd short bed, awaiting 440 swap
