Restoration Batteries #1823258
05/10/15 09:30 AM
05/10/15 09:30 AM
Central KS
Fred_Gilmore Offline OP
Central KS
I received an email from TurboStart on Friday explaining a relationship they have formed with Remy Battery. It looks like the TurboStart restoration batteries are going to be available for a limited time. Here is a link if you guys want to investigate the offer. I have not talked with Remy but will on Monday and see if I can work something with them to get us a better deal. I'll keep you posted....
Fred Gilmore
http://www.remybattery.com/turbostart.aspx
Re: Restoration Batteries [Re: Fred_Gilmore] #1823331
05/10/15 10:58 AM
05/10/15 10:58 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Thanks! I thought I missed out on getting a decent battery!
Re: Restoration Batteries [Re: Pynzo] #1825093
05/12/15 04:56 PM
05/12/15 04:56 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
If you have an old one still laying around, I have done this twice now. I cut mine apart once it died & added a Odyssey light weight racing battery inside. Not a race car, but it did go from like 54 lbs down to 18 lbs. It has more cranking amps & turns over much faster now than the re-pop Mopar red top batteries do.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Restoration Batteries [Re: 6PKRTSE] #1825095
05/12/15 04:57 PM
05/12/15 04:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
From the top in my car.
Re: Restoration Batteries [Re: Fred_Gilmore] #1825100
05/12/15 05:01 PM
05/12/15 05:01 PM
California
mickm Offline
mickm  Offline
California
i do have an old one laying around, and have been contemplating this. someone posted a step by step instruction list on how to do this, but my hesitancy has been just dealing with the mess of all the gel and lead. sounds like a pretty messy operation. i have a gel cell, so that is probably better than lead acid, but still doesn't sound like fun.
Re: Restoration Batteries [Re: mickm] #1825804
05/13/15 02:32 PM
05/13/15 02:32 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, it was messy. I wore gloves & safety glasses due to the acid. I just set the battery upside down in my oil change pan which is one of the larger pans obviously. Cut the bottom off with my cut off wheel, pulled out all of the guts. Drilled & tapped the bottom of the original lead posts. Bolted some 12" long battery cables to them & then ran the other end to the new racing battery & shoved it all in. Works great, I am on my 4th or 5th summer now on this same battery.
It took about 1-1/2 to two hours to do, with cleanup....
Re: Restoration Batteries [Re: 6PKRTSE] #1825869
05/13/15 03:46 PM
05/13/15 03:46 PM
s.e. MI
P
partsforsale Offline
P
s.e. MI
6PKRTSE,
Just curious, any specific reason you chose the Odyssey PC925 battery? I was looking on their website and saw that the battery weighs 26 lbs. and has 330 CCA....sounds like it works like it should.
Re: Restoration Batteries [Re: partsforsale] #1827498
05/15/15 08:00 PM
05/15/15 08:00 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I also gutted one. Drained and Cut the top off neat.
Then I drilled and taped the post I can go 2 ways that way, to hook up cables. I can use the washers and post as shown, and use a top post terminal.
Or a cable end with washer and bolt.
I did detail the plastic box. like you would do a yellowed head lamp.
And added some angle plastic I had with epoxy to the lid to keep it in place. Looks like angle iron but is plastic
As you can see with the red top caps it was not yet 100% polished up yet
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Restoration Batteries [Re: 340SIX] #1827596
05/15/15 11:12 PM
05/15/15 11:12 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Every once in a while hollow "display batteries" come up on ebay. I used to call on parts stores and garages while working as a sales rep and found quite a few that the owners were willing to part with at reasonable prices. I have converted several of them with Odyssey batteries or the like.
Re: Restoration Batteries [Re: Fred_Gilmore] #1828801
05/17/15 09:12 PM
05/17/15 09:12 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Fred Gilmore
just curious Fred if anything else came up as far as a better deal, thanks
Re: Restoration Batteries [Re: shakerjoe] #1830902
05/20/15 03:20 PM
05/20/15 03:20 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
Summit used to have a great price on these but everybody is out now. Just bought a couple from Antique Auto Battery and they have held up well so far. Have had trouble with the gel cell Turbo Start ones, only get a year or two out of them.
Rocket Restorations
Re: Restoration Batteries [Re: 6PKRTSE] #1830914
05/20/15 03:39 PM
05/20/15 03:39 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Are you securing the new battery in any way inside the shell? Or are the cables stiff enough to hold it from moving around too much?
Thanks!
Re: Restoration Batteries [Re: Fred_Gilmore] #1830940
05/20/15 04:16 PM
05/20/15 04:16 PM
NE Ohio
8
82firebird Offline
82firebird  Offline
NE Ohio
Great thread and ideas guys. Thanks for sharing!
Re: Restoration Batteries [Re: LimeliteAero] #1831023
05/20/15 06:37 PM
05/20/15 06:37 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Thanks!
Cables will secure the battery, but I added some heavy foam padding for extra measure.
Re: Restoration Batteries [Re: Fred_Gilmore] #1842737
06/06/15 07:22 AM
06/06/15 07:22 AM
NY
moparmatt0 Offline
moparmatt0  Offline
NY
Which battery is correct for a 70 cuda 440-6
Re: Restoration Batteries [Re: Fred_Gilmore] #1842801
06/06/15 10:46 AM
06/06/15 10:46 AM
SE Wisconsin, USA
RP's R/T's Online content
RP's R/T's  Online Content
SE Wisconsin, USA
OK, is it just me, or does it seem that just selling the empty Battery Box and creating a kit (inner cables, foam, etc) so that anyone could make their own battery as shown would be perfectly fine for 99% of us?
Why deal with a battery company?
Make a box that snaps together and I can go to a local store and buy a battery myself.
Fred, do you own the tooling for the empty box and caps?
Re: Restoration Batteries [Re: moparmatt0] #1842805
06/06/15 10:55 AM
06/06/15 10:55 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It depends, so the only way to know what it came with would be to check the battery section of your broadcast sheet if you have one for the car.
Re: Restoration Batteries [Re: RP's R/T's] #1842905
06/06/15 02:30 PM
06/06/15 02:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'm sure if someone does do that they will charge $500 for it.
Re: Restoration Batteries [Re: ademon] #1842937
06/06/15 03:52 PM
06/06/15 03:52 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Rule of thumb back in the day was 1 CCA per cubic inch of the motor. I wouldn't use a 330 CCA battery on a 318 car. Might be good for a Slant 6.
Re: Restoration Batteries [Re: Fred_Gilmore] #1843267
06/07/15 03:23 AM
06/07/15 03:23 AM
WA
tman Offline
tman  Offline
WA
It was my impression, that big blocks used a group 27 battery. Or are you talking which Resto battery? If so, the red cap later model year 1969-74.
