AAR Cuda Antenna Location ? #184949
01/05/09 08:26 PM
01/05/09 08:26 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Where on the passenger side rear 1/4 panel is the radio antenna located on an AAR Cuda?
Was this always a dealer thing or was it factory on all AAR's?
I need a good clear picture showing the location please.
CHECK OUT MY NEW WEB SITE !
Re: AAR Cuda Antenna Location ? [Re: anlauto] #184950
01/05/09 11:15 PM
01/05/09 11:15 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Here is a picture. I don't know it's history. I probably grabbed it off this site.
Re: AAR Cuda Antenna Location ? [Re: Snoopy] #184951
01/05/09 11:21 PM
01/05/09 11:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Don't know if T/A would be the same, probably is...
Re: AAR Cuda Antenna Location ? [Re: 1_WILD_RT] #184952
01/05/09 11:22 PM
01/05/09 11:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
2
Re: AAR Cuda Antenna Location ? [Re: 1_WILD_RT] #184953
01/06/09 11:41 AM
01/06/09 11:41 AM
Denmark, Helsingor
AAR70 Offline
AAR70  Offline
Denmark, Helsingor
If Your AAR cuda have R11(Radio AM ) on the fender tag ,there is faktory monted antenna. Not original deler monted.
A 53 on fender tag ,is incl radio ,or the radio is deleted,that is a rare AAR cuda.
Re: AAR Cuda Antenna Location ? [Re: AAR70] #184954
01/06/09 04:36 PM
01/06/09 04:36 PM
anlauto Offline OP
anlauto  Offline OP
Thanks guys
Re: AAR Cuda Antenna Location ? [Re: anlauto] #184955
01/07/09 08:48 PM
01/07/09 08:48 PM
cataclysm80 Offline
cataclysm80  Offline
antenae was factory installed if the car came with a radio. not sure if AAR and TA will measure out the same. The idea is to have it far enough forward that the spoiler doesn't hit it when the trunk is open.
Tav
Re: AAR Cuda Antenna Location ? [Re: cataclysm80] #184956
01/08/09 12:31 PM
01/08/09 12:31 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Not to hijack the post but how would one drill the antenna hole? The 3/16 pilot holes would be no problem but what tool to use to drill or make the 1 11/32 hole?
Re: AAR Cuda Antenna Location ? [Re: Pntastar69] #184957
01/09/09 10:12 AM
01/09/09 10:12 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
A for the last post regarding drilling the 1 11/32 hole.
Re: AAR Cuda Antenna Location ? [Re: Pntastar69] #184958
01/09/09 10:31 AM
01/09/09 10:31 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
hole saw. Drill the pilot hole, then use this
Re: AAR Cuda Antenna Location ? [Re: RodStRace] #184959
01/09/09 11:28 AM
01/09/09 11:28 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
U kidding me? This on a 69 Dart fender that has a somewhat concave surface. That'll be ok on a fender before paint. I could see the paint chips flyin all over the place. I'm talkin on a fender that has paint on it like the one in my sig.
Re: AAR Cuda Antenna Location ? [Re: Pntastar69] #184960
01/09/09 11:50 AM
01/09/09 11:50 AM
Usually when you have to saw or cut a painted fender you tape off the entire area with the blue masking tape and then drill through that. It minimizes the paint coming off and flaking.
Re: AAR Cuda Antenna Location ? [Re: Pntastar69] #184961
01/09/09 11:52 AM
01/09/09 11:52 AM
anlauto Offline OP
anlauto  Offline OP
Well that was silly....You should have drilled the hole BEFORE paint
If I were in your shoes.....I'd cover the location in duct tape...Mark the hole where you want it.
TIP: Check the hole size of the actual bezel and don't rely on the gasket.
Then I would start with a small 1" hole saw...then finish up with a die grinder CAREFULLY Slowly taking your time so that you don't heat up the surronding paint too much
Re: AAR Cuda Antenna Location ? [Re: anlauto] #184962
01/09/09 02:09 PM
01/09/09 02:09 PM
Snoopy Offline
Snoopy  Offline
Why not use a knockout punch?
Or you could scribe a circle with a compass and chain drill it, then use a rotary file to finish.
