Caravan mileage still sucks #184923
01/05/09 07:57 PM
01/05/09 07:57 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
1990 Caravan, 2.5 turbo, automatic. If my 02 sensor was bad, wouldn't I get a code flashing when I check for one? The thing runs perfect, just gets lousy gas mileage. When I rebuilt the head 2 years ago, it got 24 mpg highway, and 18 in town. Now it only gets about 13, or 14 in town ,haven't been able to check highway lately. It still runs pretty strong, no problem breaking the tires loose from a dead stop by just stomping it. Cant find any vacuum leaks, recent tune up. Doesn't show any codes when I checked it. Any ideas?
Re: Caravan mileage still sucks [Re: elmor] #184924
01/05/09 08:03 PM
01/05/09 08:03 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
Check that the turbo is spinning freely. Just went thru the same sort of problem with a turbo diesel loader at work. It was fine one week, and started eating fuel and smoking the next. Journal bearings went south and it bound up, restricting/limiting air flow and causing a rich mixture.
With EFI and an O2, it might not be the cause, but ya never know.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: Caravan mileage still sucks [Re: elmor] #184925
01/05/09 08:17 PM
01/05/09 08:17 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Nope, o2 diagnosis is not a priority for that old of a system. Even OBD2 systems can have faulty o2 sensors and not flag a code and they have many potential codes for o2 sensor issues. Since they are cheap and fairly easy to replace that would be my recomendation. Next would be to check cam timing.
Re: Caravan mileage still sucks [Re: 78D150CLUB] #184926
01/05/09 08:22 PM
01/05/09 08:22 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
If the turbo seized, wouldn't it be puking oil?
Re: Caravan mileage still sucks [Re: elmor] #184927
01/05/09 08:47 PM
01/05/09 08:47 PM
Ontario, Canada
78D150CLUB Offline
78D150CLUB  Offline
Ontario, Canada
If the seal were still intact, it shouldn't. Maybe a small amount, not major leaks. The oil should just flow past the journal to the drain as usual.
Don't quote me on that, though. I've had some experience with diesel turbos in loader engines, but not an expert by any stretch of the imagination.
Feets would likely know for sure on something like that.
Re: Caravan mileage still sucks [Re: 78D150CLUB] #184928
01/05/09 08:57 PM
01/05/09 08:57 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
How hot is the engine running. Open thermostat can run you in open loop=poor milage.
Re: Caravan mileage still sucks [Re: Skeptic] #184929
01/05/09 09:03 PM
01/05/09 09:03 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
I'm with this guy. double check your timing marks.
