Re: highest hp street small blocks on here??
[Re: DusterKrazy]
#184763
01/05/09 06:51 PM
01/05/09 06:51 PM
Posts: 1,167 ERIE PA home of the RENCH MOB
mike_vango
400hp. 9.0:1 stock bore and stroke 360. 1.925/1.625 iron heads. .501/.513 288-292 roller. 750 holley. stock ignition. 3.55s 74 swinger granny edition. 12s on whitewalls ^^i had my brothers 440 belvedere smoked before i shifted^^^
[Re: DusterKrazy]
#184765
01/05/09 07:56 PM
01/05/09 07:56 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Mine is not the fastest out there, but it is a nice street friendly combo that has been running for thousands of miles and never overheats.
340 .30 over, stock stroke with original forged crank. Stock rods, forged factory style replacement TRW pistons with 10.1 compression. Comp XE274 hydraulic cam, unported X heads, Edelbrock Air Gap intake, 650 Holley DP. 3.91 gears, PTC 3,500 converter, 28" tall drag radials. Car weighs 3,500 pounds with me in it.
Est. 400 HP at the flywheel based on quarter mile time of 12.91 @ 103.7. No nitrous, aluminum heads, or stroker needed. Still need to play with the timing too. Driven to and from the track, runs consistent within a couple thousandth so it makes a good bracket car to boot.
[Re: fasthawk6]
#184767
01/05/09 08:07 PM
01/05/09 08:07 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
73 340 Duster
Has 10.6 to 1 360 with ootb edelbrock heads, , edelbrock air gap, holley 750 dp, hughes HE3038 cam (231/237 duration),MP distributor with chrome box, tti stepped headers, 727 with stock converter and 3.23 gears, cooper II 225/60 x 14 tires.
spinning tires....14.01 @ 101.26 in Vegas.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#184768
01/05/09 10:09 PM
01/05/09 10:09 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Not sure what mine makes, probably about 350-375hp, but its a VERY simple engine combo.
'77 360 with stock pistons Magnum Heads with R/T Springs & Retainers Summit K6901 camshaft (218/228 with .441/.441 lift (.470/.470 with the 1.6 rockers) 1 5/8" headers Edelbrock Air Gap intake (Magnum type) 600 Holley.
This thing runs strong!!
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: FurryStump]
#184770
01/06/09 09:30 AM
01/06/09 09:30 AM
Posts: 1,481 Outside
thedriver
Outside
not the highest, but runs good, for a street car
340ci 10.5 cr, eddie heads, 750 demon, air gap and a XE285HL cam from comp, 3500lb car with me in it, 727, 3.9 gear,,, best is listed in my sig.
1973 challenger Dana. 4 speed. Low deck.
[Re: mike_vango]
#184773
01/06/09 03:55 PM
01/06/09 03:55 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Not highest but.. +.030 360, stock crank and rods speedpro flat tops at zero deck home ported j's, 2.02 torker II, 750 Dp Comp solid 520/540 .244/.252 @ .050 Demon with a auto and 3.91 26" tall slicks 12.22 at 109.5 mph, 1.66 60' First and only time at track, was to rich & didn't even play with timing ! so simple and cheap its not even funny!
[Re: dusterjp]
#184775
01/06/09 08:00 PM
01/06/09 08:00 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
360 block, 408 stroker. forged Ross pistons (10.2:1), Eagle cast crank, H beam rods, .600 lift, scorpion rockers, Isky springs (can't remember rate), Scott Brown custom ground hydraulic cam (248/254@.50) Ported Eddy heads flow 284 cfm (gasket matched), stock M1 intake, Proform carb... flows like an 850. TTI headers. 480 horsepower, 500 ft. lbs. tq. With a 3.91 rear and a 4 speed, it's all you need on street tires... I spin through 3rd gear. If I were building from scratch, I'd only change the carb and MAYBE up the compression to 10.5-10.7 or so. Buy a Demon. My money is far better spent on tires at this point though if I were looking for the best e.t. and since I don't race, I don't need slicks or drag radials, so basically I am where I need to be: HAPPY!
[Re: DusterKrazy]
#184776
01/06/09 08:45 PM
01/06/09 08:45 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Heres mine.
1971 360 block Eddy heads ported by Hughes milled to 57cc chambers Flat top KB. pistons 11.7-1 comp runs fine on 93 octane Smith brothers pushrods Comp cams custom grind- .544 intake/.576 exhaust with 1.6 rockers, duration at .050 242/254 Stock crank and rods M1 single plane intake with super sucker spacer 950hp holley carb msd ignition 6al with a billet dist. Dynamic 9 1/2 converter 727 trans 4.10 gears
Best et. = 11.24 @ 121 421 hp at the wheels.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: CoyoteJack]
#184778
01/07/09 04:30 PM
01/07/09 04:30 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
Ok here is my combo:
+0.035 over 340 4" Eagle forged crank reconditioned stock rods custom forged Venolia pistons 9.5:1 compression stock 340 'X' heads completely gone thru (no porting) Mopar Performance 484 Purple Cam (241/241, .484/.484 lift 108 lsa) new stock stamped rockers Edelbrock RPM airgap mainfold (dual plane) Holley 770 Street Avenger carb (it has been re-jetted) FBO ignition system TTI headers and TTI 3" exhaust system with Flowmaster 40 mufflers 3.91 gears 4-speed 70 Cuda
The car dyno'd at 375 peak RWHP when the clutch started to slip at 5000rpm (so there is still more HP in there) and 484 peak RWTQ. Figuring a 10% loss for the drive train this puts the HP at about 420 at the crank (when the clutch started to slip) and 537 TQ at the crank.
Future plans for the motor:
-Ported Eddy heads -10.5:1 (or higher) compression -Roller hydralic cam and rockers (the cam will have a little bit more duration and more lift then the current cam) -850 Holley DP Carb
With these upgrades I hope to make around 500HP/500TQ at the crank. Looking at what other people have posted with their combos this should be possible.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: loco340cuda]
#184779
01/07/09 10:13 PM
01/07/09 10:13 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Here's the one I plan to bracket race....Quick77R/T built the shortblock 360+.030 roller block 11:1 Eddie closed chamber Heads...bowl blend, Good VJ and open the pushrod pinch to .980 (per RyanJ's recommendation) Hydraulic Roller 236/240@.050 ..554/.540 lift 112 centers, 107ICL 1.6I 1.5E rockers Performer RPM...minor porting 830 annular Holley 1 3/4 headers 904 Lock-up w/Shift kit 3200 stall 10" converter * 3/4" b body rear, 4.10 gear 28" x 10.5" slick Should be similar to a few others here like Ademon's. A basic, reliable, powerful, nice combo. Looking to go consistent 7.50's in the 1/8th in a 1992 Daihatsu Rocky that weighs ~2950 lbs w/me in it. 87" wheelbase so that's why I spread the lobe centers and oversized the carb to kill a off idle and little midrange (shiftpoint) torque to make it more tractible until I get a handle on how to make it go rounds. I may go to a single plane if it still has too much torque off the line or a Vac secondary if it goes a little too quick. I figure it should make ~425 (well probably a good bit more )by ~6000rpm pretty easily.
[Re: Streetwize]
#184780
01/07/09 10:30 PM
01/07/09 10:30 PM
Posts: 1,546 Leetonia, OH
R6T8net
Leetonia, OH
416 stroker Forged crank, H beams 10.1:1 Full roller Ported eddy's Airgap 850 Mighty Demon
"Who is John Galt?"
68 Coronet RT LL1 Auto 70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far 01 2500 Quad Cab 4x4 Cummins
[Re: R6T8net]
#184781
01/07/09 10:49 PM
01/07/09 10:49 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
416" Shady Dell ported W-2's, 272 @ .050 .610 lift Racer Brown, 17/8" TTI's, PF 950HP, TA 4400 convertor, 4.30 gear, ported Indy intake, 3500 lb. A body. 11.08 @ 120 mph
