46-50 Mopar ID and frame info (DIALUP KILLER!!!) #352765
06/20/09 03:56 PM
06/20/09 03:56 PM
Chino Valley
RodStRace Offline OP
Chino Valley
I just picked up an old book and decided to share some of it with the members here. Lots of people here have helped me, and there have been questions on frames and frame swaps. I hope this can be used for some of those questions.
Chrysler
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352766
06/20/09 03:58 PM
06/20/09 03:58 PM
Chino Valley
Chino Valley
Desoto
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352767
06/20/09 04:00 PM
06/20/09 04:00 PM
Chino Valley
Chino Valley
Dodge
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352768
06/20/09 04:02 PM
06/20/09 04:02 PM
Chino Valley
Chino Valley
and finally, Plymouth
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352769
06/20/09 04:43 PM
06/20/09 04:43 PM
Chino Valley
Chino Valley
I went ahead and found the 1992 Dakota frame specs too. I was not able to grab an earlier one.
I haven't printed these out and compared, but for those wanting to tackle a frame swap, HERE'S YOUR INFO!!!
BTW, these are metric measurements...
and the other measurements are attached.
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352770
06/22/09 08:42 AM
06/22/09 08:42 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
I think I have a 1990 Dakota service manual if I can find the frame drawing I will post it up here. I am assuming most would be interested in the 112" wb frame?
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: bohmer2] #352771
06/22/09 10:46 AM
06/22/09 10:46 AM
Chino Valley
Chino Valley
A 1990 frame should be the same and the info would be in the body service manual, but if you have it please post.
Many have asked what frame fits the older cars, and some have used the Dakota chassis. Since I have not done this, I just wanted to provide what hard data I could for those interested in trying.
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352772
07/10/09 09:44 PM
07/10/09 09:44 PM
Chino Valley
Chino Valley
Just a for those that missed it.
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352773
07/25/09 06:35 PM
07/25/09 06:35 PM
Chino Valley
Chino Valley
Found a 1937 frame spec on another site, so here it is.
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #352774
02/04/13 11:03 PM
02/04/13 11:03 PM
Chino Valley
Chino Valley
bump for a recent post
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #1845189
06/09/15 07:53 PM
06/09/15 07:53 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Some great info I needed here thank you
Just about to put a 340 in a `40 Dodge, seems the Dakota swap would work out well.
Any been there done that input will be helpful. Just picked up the car but no mods done yet just research.
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: 67R/T4speeder] #1845470
06/10/15 12:19 AM
06/10/15 12:19 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I put a 48 Plymouth business coupe on a 90 Dakota frame. I used the entire frame because the coupe's frame was complete junk. (put your hand through the top of the frame rail kind of junk.)
I used a long box, standard cab and had to take 8" out of the Dakota wheel base. I also used the Dakota floor pan and bottom 1/2 of the firewall. When I shifted the "cab" (the floor pan and firewall) towards the rear 7", the firewalls between the 48 Plymouth coupe and the modified Dakota matched up perfectly. I modified the Dakota cab mounts so I could reuse them. I also used the entire Dakota drive train, which I also shifted towards the rear 7" to match up with the "cab" placement. I trimmed the Dakota floor pan and set the coupe body down onto it, built rockers, and attached the Dakota floor pant to the coupe body.
The biggest issue is the Dakota frame kicks up 6" once it gets behind the cab. I used the Dakota box floor as well and I have a step up on the floor, behind the seat. My car is a business coupe without a back seat, so the step up is not an issue, but if you intend on having a back seat, something else would have to be done.
My car has 3 summers of driving on it. The car is a blast to drive (EFI V6, 5 speed, 3:55 limited slip). Gene
Re: 46-50 Mopar ID and frame info (DIALUP KILLER!!!) [Re: RodStRace] #1845706
06/10/15 01:10 PM
06/10/15 01:10 PM
Caldwell, Idaho
Caldwell, Idaho
That looks like a fun MoPar
Thanks for the ideas
