I had a round sump welded into the bottom of the stock tank and ran a #10 AN teflon flex line to the filter which was screwed into the inlet side of the pump, #8 hard line to the reg. up front
I had the stock fuel pickup and sender out and had a #8 AN nipple welded into it so I could use it for the # 8 AN return line from the bypass on the pump, it worked well after I got the proper size fuel filter element(80 micron or bigger
) in the pre pump filter. I mounted the pump in the right rear corner behind the stock tank on the inner rear sub frame
I made sure the bottom of the pump was level or slightly lower than the pump outlet was also , if I'm remebering correctly now
