1970 E-BODY BRAKE CYLINDER BOOSTER DETAILS.. CABLE BRACKET #1838763
06/01/15 03:28 PM
06/01/15 03:28 PM
Sweden
71redcuda Offline OP
Sweden
Hi,
The bracket that mounts on to the side of the brake cylinder.. what finish should it have, painted gloss black?? (exept for the rubber coating).. Im guessing this bracket was not mounted during painting the brake booster & cylinder as an assembly..
same with the nuts that holds the bracket, are they phospahte coated?
Nicklas-Sweden
Re: 1970 E-BODY BRAKE CYLINDER BOOSTER DETAILS.. CABLE BRACKET [Re: 71redcuda] #1840850
06/03/15 09:31 PM
06/03/15 09:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Galvanized with a black phosphate speed nut
Re: 1970 E-BODY BRAKE CYLINDER BOOSTER DETAILS.. CABLE BRACKET [Re: 71redcuda] #1843506
06/07/15 04:44 PM
06/07/15 04:44 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here is a picture of an NOS booster kit that sold on ebay last week. This bracket supplied as a prt looks to have been gloss black.
Re: 1970 E-BODY BRAKE CYLINDER BOOSTER DETAILS.. CABLE BRACKET [Re: 71redcuda] #1844009
06/08/15 07:18 AM
06/08/15 07:18 AM
Sweden
Sweden
Thanks for the picture & info. I did mine in semi gloss black.
