Re: School me please on electric fuel pumps [Re: MikeyT] #1844047
06/08/15 09:51 AM
06/08/15 09:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You could do it the right way and figure .5 pounds
per hour per HP to figure out what size pump you need
and add a bit more if you plan on more power
wave
Re: School me please on electric fuel pumps [Re: 383man] #1844077
06/08/15 11:15 AM
06/08/15 11:15 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Originally Posted By 383man
If he is like me I will take an electric pump over a mechanicalal any day. I would rather have my fuel being pushed up under pressure then pulled under vacum since that alone helps fight vapor lock. We all know the fuel will vapor lock easier under vacum then under pressure. Ron
I agree! the Hemi in my challenger (Shaker hood), had vapor lock issues due to the ethanol laced pump gas around Reno, so a factory vapor separator install cured the issue, but not for long. The repop pushrod was short & took out the cam lobe, so electric pump was the fix. I got the Holley 150 gph gerotor design pump since it was super quite & didn't want the noise of the vane design blue pump. Worked fantastic & was super quiet. Same thing happened on my 383 mag, so I went with the Mallory gerotor pump & its even quieter & smaller than the holley. If you don't want the noise, try one of these.
http://www.summitracing.com/nv/parts/hly-12-150/overview/
or
http://www.summitracing.com/nv/parts/maa-5110fi/overview/
Re: School me please on electric fuel pumps [Re: MikeyT] #1844166
06/08/15 01:45 PM
06/08/15 01:45 PM
I had a round sump welded into the bottom of the stock tank and ran a #10 AN teflon flex line to the filter which was screwed into the inlet side of the pump, #8 hard line to the reg. up front up I had the stock fuel pickup and sender out and had a #8 AN nipple welded into it so I could use it for the # 8 AN return line from the bypass on the pump, it worked well after I got the proper size fuel filter element(80 micron or bigger up) in the pre pump filter. I mounted the pump in the right rear corner behind the stock tank on the inner rear sub frame scope I made sure the bottom of the pump was level or slightly lower than the pump outlet was also , if I'm remebering correctly now whistling
Re: School me please on electric fuel pumps [Re: MikeyT] #1844762
06/09/15 02:32 AM
06/09/15 02:32 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks guys,
As always very informative!
Mikey
1969 Dodge Dart Swinger
Re: School me please on electric fuel pumps [Re: MikeyT] #1844821
06/09/15 10:23 AM
06/09/15 10:23 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You do not need - 8 feed line (1/2"). The 3/8" you have is fine.
I run E85 (30% more fuel then gas), boost (horrible BSFC), and still make 800hp on - 8 feed.
