Dumbell mech lifter.....
#184341
01/05/09 12:40 AM
01/05/09 12:40 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
How much lift can a dumbell style mechanical lifter take before running into problems on a RB block? Obviously you dont want the narrowed portion of the dumbell coming out of the lifter bore. Will they take say .340 cam lift?
Re: Dumbell mech lifter.....
[Re: NTOLERANCE]
#184342
01/07/09 07:15 PM
01/07/09 07:15 PM
NTOLERANCE
Madison Wi
Anyone?
If not, guess I will mock it up .....
[Re: NTOLERANCE]
#184343
01/07/09 09:29 PM
01/07/09 09:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would say if they will work on a stockish lift cam then it will not poke out the lifter bore with a high lift cam because they actually make the base circle smaller not really the peak higher, mabey a hair. I do know on a small block some cams will let the lifter go too low and bleed oil out the bottem.
[Re: HotRodDave]
#184344
01/07/09 10:59 PM
01/07/09 10:59 PM
NTOLERANCE
Madison Wi
Thanks Dave, thats something I will keep an eye on. I can get a good deal on a set of them, and my new Crower mech cam didnt come with any lifters.
Thanks again.
Doc.
