Re: The new M/T radial slick.
[Re: grncpe]
#1847687
06/12/15 09:36 PM
06/12/15 09:36 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Racerx, forgot to mention cal trac mono leaf with bars, cal trac shocks with the Hemi . Santhuff shocks with the 383 Hey Ron , it weighed 3195 without me and a alum headed Hemi . 383 ss motor was 3050 without me. All off the nose of the car. Of coarse I had to add some weight to it as I have to weigh 3470 for ss/ja. I have been running it at 3560 ish so I will lighten it up a little also to get it a little closer to min weight. That is with me in the car. Thanks Tom. If you dont mind me asking do you know the HP that 383 makes. I dont know anything about your 383 but thats a strong 60 so it sure sounds like a strong 383 stocker eng. How fast has it gone with that stout 383 ? Thanks , Ron
[Re: grncpe]
#1847829
06/13/15 12:40 AM
06/13/15 12:40 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I was on Mickey Thompson's web sight and they have 2 different NEW tires I am interested in. The ET Drag Radial 29.5/10.5 with the R1 compound and the Pro Bracket Radial 29.5/10.5 with X5 compound. All the specs are the same except the compound and the ET Drag Radial is 2 lbs lighter. I am running the 315/60 ET Street Radial now that is the same height but 1 in wider. I would think the first 2 would be the best of both words since they do not have any tread and are a radial but they are 1 in narrower. Which one of the 2 new ones work the best?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1847928
06/13/15 09:25 AM
06/13/15 09:25 AM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
D-50, You may want to try asking Jason Moulton , from MT , over on Yellowbullet . He was helpful to me , though i have gone back to Hoosier radials . I have tried the lightweight Hoosier 9x30 , 29.9 dia . Was very happy but did not have enough gear . I am only a small radial guy , Hoosier 275 , with not enough power .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
