Which brand of hyd ft cam and lifters do you recommend? #1841264
06/04/15 11:02 AM
06/04/15 11:02 AM
Springfield, MO
Steve88 Offline OP
Steve88  Offline OP
Springfield, MO
I am getting ready to do a cam swap in my 71 383 and I want to start with the best qauilty cam and lifters I can. I know that proper cam break in and proper oil is very important to the life of a hyd flat tappet cam but I want to make sure I use the best made products possible to try to make sure there are no flat cams in my future. I am not completely opposed to Comp Cams but I do avoid them when possible due to a past experience. This will be a very mild street type of cam. Thanks!
Re: Which brand of hyd ft cam and lifters do you recommend? [Re: Steve88] #1841293
06/04/15 11:34 AM
06/04/15 11:34 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Crane or Isky....IMHO
Re: Which brand of hyd ft cam and lifters do you recommend? [Re: Steve88] #1841911
06/05/15 02:06 AM
06/05/15 02:06 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
SpeedPro HT2011R, this is the anti-pump up lifter...maybe be overkill for a mild build...but the price is on par with other anti-pump up lifter sets...
Re: Which brand of hyd ft cam and lifters do you recommend? [Re: Steve88] #1841946
06/05/15 05:44 AM
06/05/15 05:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I built my 493 I had a custom grind made for it and I went with Dwayne Porter who is one of the best there is on cams. If you call him and give him all your cars specs and tell him how you want the cam to work he will spec and make your cam for no more then most off the shelf cams. But he will know what will work the best for you as he is an expert on cams. I could not be happier with my flat tappet solid cam he made for me. He also nitrides the cam which harden's it and will get you the best lifter to use. His # is 802-951-1955 if you decide to call him. he is also very nice to talk with and wil help you with any questions. Ron
