dead spot #184164
01/04/09 09:46 PM
01/04/09 09:46 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
i have a 440 n my mopar. about 5800 it kind of falls on its face. bored .030,torkerII intake,800 holley,i had a blue pump on it but i burnt 2 of them up so i put on a carter mechanical pump. it is 9.5to1 compression ported 452's and a voodoo hydraulic 276/284 .513/.533 cam. Any help would be appreciated.
Re: dead spot [Re: bigblock4x4] #184165
01/04/09 09:51 PM
01/04/09 09:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Time to test... have you checked fuel pressure yet.
Have you checked your valve springs
Re: dead spot [Re: MR_P_BODY] #184166
01/04/09 11:25 PM
01/04/09 11:25 PM
pana illinois
pana illinois
it has 7 lbs fuel pressure,i personally dont have the tools to check the valve springs. a local man set the heads up for me.
