Re: Who's flat solid cam? SB
[Re: justinp61]
#1839549
06/02/15 09:20 AM
06/02/15 09:20 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I have always called Dwayne Porter, and had him spec and order a cam for me. He is the man
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: justinp61]
#1839630
06/02/15 12:15 PM
06/02/15 12:15 PM
Posts: 7,506 Az
Crizila
Az
I'm need a flat solid cam for my 340, the hydraulic in it now is bad. This is the motor I built for my Dart in 03 and replaced it with a 408 in 09. I bagged the short block and put it on a shelf.
Over the winter I pulled the 408 to freshen it and found some odd cam and main bearing wear and the flat solid cam was on it's way out. I bought a 395" R1, Indy head motor, sold the rotating assembly and am gathering parts for a 434" build.
So..........I thought I'd bring the 340 out of moth balls, put the heads and intake back on, check the bearings and run the pi$$ out of it until I have the new motor built. Wrong! While looking it over today before mounting it on the engine stand I noticed some pitting on the nose of one of the lobes. After closer inspection there is another lobe showing the same, so this cam was on it's way out too. Both cams were from the same company and had been ran for about five years.
I need another cam. Who do you guys recommend? Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years.
Fastest 300
[Re: B3422W5]
#1839658
06/02/15 12:39 PM
06/02/15 12:39 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[Re: qwkmopardan]
#1839677
06/02/15 01:10 PM
06/02/15 01:10 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo. Totally agree with this.
[Re: Crizila]
#1839740
06/02/15 02:26 PM
06/02/15 02:26 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years. I haven't miced the cam. The 340 cam has two lobes that have pitting on the nose of the cam. one of the lobes shows wear all the way across the lobe with pits that will catch you fingernail. The bottom of that lifter looks to have been hit with a tiny needle scaler. The other lobe is just starting to pit. The rest of the lifters and lobes look perfect. The 408 had EDM lifters in it and has several lobes and lifters as I described above.
[Re: justinp61]
#1839810
06/02/15 03:51 PM
06/02/15 03:51 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years. I haven't miced the cam. The 340 cam has two lobes that have pitting on the nose of the cam. one of the lobes shows wear all the way across the lobe with pits that will catch you fingernail. The bottom of that lifter looks to have been hit with a tiny needle scaler. The other lobe is just starting to pit. The rest of the lifters and lobes look perfect. The 408 had EDM lifters in it and has several lobes and lifters as I described above. What company? Was it a big cam? What oil were you using?
[Re: B3422W5]
#1840067
06/02/15 10:22 PM
06/02/15 10:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have always called Dwayne Porter, and had him spec and order a cam for me. He is the man Same here as Dwayne speced and ground my cam and supplied the EDM lifters and I could not be happier. Ron
[Re: qwkmopardan]
#1840194
06/03/15 12:42 AM
06/03/15 12:42 AM
Posts: 1,532 off the grid
340B5
off the grid
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo. How much compression does the STX-21 need to work well?
Yeah, it's got a smallblock.
[Re: justinp61]
#1840333
06/03/15 10:05 AM
06/03/15 10:05 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Predator cam Mt Carmel pa. He has lots of different Mopar cam cores.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: justinp61]
#1840454
06/03/15 01:34 PM
06/03/15 01:34 PM
340B5
off the grid
The STH42 I put in my 340 knocked off nearly .4 on my 340 vs a comp XE295HL. The ST-21 is the STH-42's evil twin.
[Re: ademon]
#1840724
06/03/15 07:21 PM
06/03/15 07:21 PM
1967dartgt
Hilltown Pa
What ever cam you go with I would dump the rottela in favor of dedicated race Oil like VR1 or Brad Penn just to name a couple. Rotella works in my motor, Brett Millers motors and Fishy340, who just made 813hp na with his small block on the dyno, just fine. I have better oil pressure with rotella 15\40 then Brad Penn 20\50.
[Re: justinp61]
#1841081
06/04/15 12:44 AM
06/04/15 12:44 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
71 Dart has a Hughes 260/264 71 Demon has a Hughes 256/265 71 Duster has MP 590 soon to changed to a Hughes 260/264
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: qwkmopardan]
#1841357
06/04/15 01:05 PM
06/04/15 01:05 PM
BradH
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo. I like Jim at RB and ran pretty well w/ an ST-21 in my 440. But those are some OLD grinds, and cam lobes have evolved dramatically in the decades since those masters were hand-designed. The biggest difference, IMO, is valve train stability at high(er) RPM. When I dynoed three different cams (two UltraDyne .904" SFT and the ST-21), the UltraDynes would rev cleanly to about 6800, even though that was well past the HP peak. The Racer Brown, on the other hand, went into total valve train crash about 6400-6500. On the the track, if I was running my 28" tall tires insted of my 29", the shorter tires would put the engine right up into the valve float at peak RPM and the car would just freakin' stop accelerating. If I ran the 29" tires, the taller tires kept the RPM down enough to keep from having to rev that high and it would pull about 2 MPH more. This was using ported OEM heads w/ 3/8"-stem 2.14" x 1.81" valves and valve springs having about 140#s closed and 380# open pressure, so it wasn't a lack of spring load. The dynamics are simply crude in comparison by virtue of how long ago they were designed.
[Re: BradH]
#1841400
06/04/15 01:44 PM
06/04/15 01:44 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo. I like Jim at RB and ran pretty well w/ an ST-21 in my 440. But those are some OLD grinds, and cam lobes have evolved dramatically in the decades since those masters were hand-designed. The biggest difference, IMO, is valve train stability at high(er) RPM. When I dynoed three different cams (two UltraDyne .904" SFT and the ST-21), the UltraDynes would rev cleanly to about 6800, even though that was well past the HP peak. The Racer Brown, on the other hand, went into total valve train crash about 6400-6500. On the the track, if I was running my 28" tall tires insted of my 29", the shorter tires would put the engine right up into the valve float at peak RPM and the car would just freakin' stop accelerating. If I ran the 29" tires, the taller tires kept the RPM down enough to keep from having to rev that high and it would pull about 2 MPH more. This was using ported OEM heads w/ 3/8"-stem 2.14" x 1.81" valves and valve springs having about 140#s closed and 380# open pressure, so it wasn't a lack of spring load. The dynamics are simply crude in comparison by virtue of how long ago they were designed. I think the question was about small block cams. Funny how we have SEVERAL small blocks on this site running 9's with bargain basement heads with Jim's (Racer Brown) cams.
[Re: pittsburghracer]
#1841451
06/04/15 02:45 PM
06/04/15 02:45 PM
BradH
I think the question was about small block cams. Funny how we have SEVERAL small blocks on this site running 9's with bargain basement heads with Jim's (Racer Brown) cams. Understood, but the lobes aren't any different when they're ground on a SB core than a BB. And that's why I pointed out the valve style (heavy 3/8" BB valves) and spring load used to put some context around the results. The ST-21 was in my car when it ran its first 10.9 pass, so I'm not saying they don't work OK. But lobe designs have advanced since the more popular Racer Brown profiles came out in the '60s. I believe the info that I provided is an example of how that shows up in the real world.
[Re: 440charger500]
#1842994
06/06/15 06:28 PM
06/06/15 06:28 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Call Hughes Engines and they will help you decide which of their cams you need. I always had good luck with their solid cams.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
