Re: Dynomax mufflers [Re: 383man] #1840112
06/02/15 10:52 PM
06/02/15 10:52 PM
NY
Beep Beep Offline OP
NY
That sounds amazing.
Re: Dynomax mufflers [Re: Beep Beep] #1840120
06/02/15 11:04 PM
06/02/15 11:04 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
My previous car 71 Duster 340 race car I went from open exhaust 11 inch extentions to 3 inch tti x pipe 3 inch dynamax bullets and went faster. It was loud but not as bad as open then went to 3 inch ultraflow ran the same but was so quiet at idle I couldn't here it at the start line. Went back to the bullets. I ran 11.30s stock stroke 340. Fun car to drive its been gone 3 weeks and I miss it. My neighbors are happy though its amazing how well you can run with a full exhaust.
Re: Dynomax mufflers [Re: Beep Beep] #1840966
06/03/15 11:04 PM
06/03/15 11:04 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
The car I am currently building is at the fab shop getting a 3" header to bumper system with pypes racepro mufflers. When I took them out of the box I could see right trhough them-- Hope they aren't too loud. Kevin
71 gtx.....
Re: Dynomax mufflers [Re: sleddinfool] #1841009
06/03/15 11:48 PM
06/03/15 11:48 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
They will be very loud - trust me. Any 3" straight-through muffler will be a lot louder than a 2.5" muffler.
The flow specs listed look like they came right from Dynomax - or they were tested the same way using 20.3" H2O as the gauge. To the OP, if you have 550 HP & were running dual 2.5" Super Turbos, they will provide approx. 380 loss-free horsepower, so yes they were restrictive to an extent. The stainless 2.5" x 20" bodied Ultra Flows will flow 1075 sCFM, & are rated at 978 loss-free HP in a dual system. I also believe they will not be too loud - they may not be much louder than the Super Turbos until you are all the way in the throttle. These would be my first choice for a stock-looking muffler setup if I wanted an oval muffler & maximum flow. Most of the guys in the Pure Stock drags use Ultra Flows. If you have room for resonators in the system (maybe back in the tailpipes?), you could add those also for extra noise control if you need it. I can build you some in any length if you need something compact & effective.
Another muffler I really like the looks of (internally), are the Cherry Bomb Vortex mufflers, except they are built like boxes. Internally however, they have a really close design to some I designed a few years ago & I've heard a few sound clips with these mufflers installed & I like the way they sound. Plus, they will flow very well although I've never seen flow specs on these under the same type of baseline testing we did at Dynomax.
Re: Dynomax mufflers [Re: Beep Beep] #1841056
06/04/15 12:26 AM
06/04/15 12:26 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thanks. Ron
Re: Dynomax mufflers [Re: 62maxwgn] #1841217
06/04/15 09:25 AM
06/04/15 09:25 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Originally Posted By 62maxwgn
Your choice !
OEM..................................... ........................................ ...225
Gibson SuperFlow 788200.................................. ............311
TTS Bullet Cat Converter............................... ..................324
Flowmaster 40 series 42540................................... .......352
Flowmaster 50 Series.................................. ...................362
Flowmaster 40 series 43040................................... .......392
Dynomax Super Turbo................................... .................410
Flowmaster 62631................................... .......................435
Carsound Cat Converter............................... ..................436
FLP Cat Converter............................... ............................440
Edelbrock Victor 5535.................................... ..................562
Flowmaster 40 series 435409.................................. ........576
Edelbrock RPM series 5511.................................... ..........579
Flowmaster Delta Force Racing 54040-10........................634
Edelbrock 304 series 5560.................................... ...........640
Edelbrock Gen App 5505.................................... ..............708
Dynomax Race Magnum Welded 17216...........................711
Borla XR-1 40600................................... ..........................836
Borla XR-1 40615................................... ..........................854
Dynomax UltraFlow SS 17263................................... .......1000
Dynomax Race Magnum Welded 17218...........................1000
Borla XR-1 40575................................... ..........................1100
Dynomax UltraFlow............................... ...........................1133
Edelbrock Victor 5537.................................... ..................1400
Borla XR-1 40450................................... ..........................1400
Borla XR-1 40741................................... ..........................1450
Dynomax UltraFlow SS 17296, 17268..............................2200
Dynomax Race Magnum Welded 17220, 17224...............2200
Dynomax Race Magnum Welded 17225...........................2600
Are these figures ALL for 2 1/2??
Re: Dynomax mufflers [Re: Alchemi] #1841359
06/04/15 01:05 PM
06/04/15 01:05 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Your choice !
No - 2.5" & 3" combined I guarantee you. This list should have been separated by the different size mufflers.
Re: Dynomax mufflers [Re: Sunroofcuda] #1841408
06/04/15 01:52 PM
06/04/15 01:52 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The Cherry Bomb Vortex apparently flow just a few cfm below what a straight 3" pipe will. They're probably what I'm going to use on my '67 Coronet when I put a 3" system on it
Re: Dynomax mufflers [Re: WO23Coronet] #1841508
06/04/15 04:08 PM
06/04/15 04:08 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Here's the internal design of the Cherry Bomb Vortex:
Re: Dynomax mufflers [Re: Beep Beep] #1841534
06/04/15 04:48 PM
06/04/15 04:48 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
" One is exactly the same length as my super turbo which is 20"s. The other is 14"s. Does it matter which length I choose?"
Yes, the shorter and/or high flow will be louder. Loud can give your subconscious a headache on longer drives. Convertibles especially.
Re: Dynomax mufflers [Re: Lefty] #1841821
06/05/15 12:02 AM
06/05/15 12:02 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Here is how the DynoMax sound on my roadrunner. Its a prety much stock 383 with TTI headers.
https://youtu.be/IrvhuBVRqQk
Re: Dynomax mufflers [Re: Sunroofcuda] #1841997
06/05/15 10:17 AM
06/05/15 10:17 AM
Alchemi Offline
Alchemi  Offline
Are these figures ALL for 2 1/2?? [/quote]
No - 2.5" & 3" combined I guarantee you. This list should have been separated by the different size mufflers. [/quote]
lol, went and looked at some part numbers, some of them are 4"-5" - im not too sure some of the bigger ones are accurate either 2200cfm seems a bit more than what a bare 4" pipe would flow?
Re: Dynomax mufflers [Re: Beep Beep] #1843701
06/07/15 09:21 PM
06/07/15 09:21 PM
NY
NY
Hi Guys,
I ordered the ultra flow mufflers in 2 1/2". I am thinking I may have made a mistake and should switch my complete exhaust system to 3". My TTI collectors are 3" then they reduce down to 2 1/2" to my TTI Xpipe. I know the motor will make 550-600hp on my current build. This is a 500 cube used for the street. I believe the FAST class is running 2 1/2". What about changing the x pipe to 3" and also the ultra flows then reduce them to 2 1/2 for the tail pipes?
Re: Dynomax mufflers [Re: Beep Beep] #1843705
06/07/15 09:29 PM
06/07/15 09:29 PM
Central NC
gch Offline
gch  Offline
Central NC
A lot of work for a street car.Sure it may make a few more ponies but is it worth the expense?You will already be up a few ponies from switching to the ultra flows.Drive it as is first and see how you like it.
Re: Dynomax mufflers [Re: Beep Beep] #1844278
06/08/15 03:41 PM
06/08/15 03:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
3"
Re: Dynomax mufflers [Re: Beep Beep] #1844601
06/08/15 11:11 PM
06/08/15 11:11 PM
NY
NY
I am sure by just switching to the ultra flow's from the super turbo's will make a difference.
