07 instrument cluster problem #1835194
05/27/15 12:13 PM
05/27/15 12:13 PM
St Leonarc Md
stormer41 Offline OP
St Leonarc Md
A friend of mine has an 07 1500 4x4. While driving,the warning icons on the instrument panel will come on, just like your first starting the truck. The gauges will do a full sweep and return to normal. This happens while driving. The truck has been checked for codes and nothing there. Can anyone give some insight??
Proud owner of a 1991 Dodge Ramcharger LE 2wd.
Re: 07 instrument cluster problem [Re: stormer41] #1836532
05/29/15 11:02 AM
05/29/15 11:02 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
It sounds like it loses power for a moment then comes back up. There probably won't be any codes because codes are erased from memory when power is cut. This is likely a bad ground or loose/chafed/corroded wire or connector somewhere. Look at the battery first, check the connections and wires, make sure they are clean and tight.
Also, maybe look at the B+ feed to the fuse box, make sure it's tight.
Was it worked on at all? Someone may have left something loose or disturbed a wire.
You might have to bring it somewhere If you don't find anything obvious. Have them try to reproduce the problem on a test drive and maybe monitor voltages that feed the cluster with a scan tool. Monitoring voltages might not tell the whole story either but it's a place to start.
'71 Duster
'72 Challenger
'17 Ram 1500
