I need some help finding a few parts.... #1834920
05/26/15 11:07 PM
05/26/15 11:07 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I need an aluminum RB distributor hold down....Can't find one
I also need those plastic carburator float adjustment gaskets...Links would be great.
Re: I need some help finding a few parts.... [Re: Dragula] #1834929
05/26/15 11:19 PM
05/26/15 11:19 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: I need some help finding a few parts.... [Re: Dragula] #1834943
05/26/15 11:40 PM
05/26/15 11:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I see a lot of paper ones on Jegs website.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: I need some help finding a few parts.... [Re: Dragula] #1835172
05/27/15 11:25 AM
05/27/15 11:25 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I believe AED sells the plastic float adjustment screw washers --> aedperformance.com
wave
Re: I need some help finding a few parts.... [Re: Dragula] #1835180
05/27/15 11:41 AM
05/27/15 11:41 AM
PA
ajcasini Offline
ajcasini  Offline
PA
Check out BO Laws Performance for carb parts.
http://blp.com/
They have what you need and more.
I may also have a couple sets. Let me see what I have and will let you know later today.
Re: I need some help finding a few parts.... [Re: forphorty] #1835519
05/27/15 08:37 PM
05/27/15 08:37 PM
Dragula Offline OP
Dragula  Offline OP
Perfect.....I will order a couple...
I bought a ton of those, and they do not hold up at all.
wave
I will look them up....
quote=ajcasini]Check out BO Laws Performance for carb parts.
http://blp.com/
[/quote]
Could not find them on his site.
Re: I need some help finding a few parts.... [Re: Dragula] #1836479
05/29/15 07:45 AM
05/29/15 07:45 AM
pa
572charger Offline
572charger  Offline
pa
mine is a CSR piece from summit !!!
hows the hemi !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: I need some help finding a few parts.... [Re: Dragula] #1836672
05/29/15 02:21 PM
05/29/15 02:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Braswell has them, click on the gasket section. IMO best to just call and order them. I thought Quickfuel had them too but Braswell does make a lot of their stuff too.
http://www.braswell.com/
Re: I need some help finding a few parts.... [Re: 572charger] #1837023
05/30/15 12:25 AM
05/30/15 12:25 AM
Dragula Offline OP
Dragula  Offline OP
hows the hemi !!!
Its pretty much done. I waited 5 weeks for an oil pan and finally gave up and used my old one after hacking it to pieces to clear the stroke.
The only issue is we have a rocker stand not allowing oil to one set of the rockers. We will fix that tomorrow probably....Otherwise, its all done. How is yours coming?
