I just took my axles up to NAPA to have them replace my bearings.....the machinist looks at my existing bearings and says "You know, usually, the taper is the other way"....basically saying the existing bearings are on backwards?
I have never replaced these since I've owned the car and I've not had any issues up until my seals giving way and having the grease washed out on them this past summer.
Does this make any sense? I told him to put the new ones on the same as the existing ones at this point.
Any ideas on what he's seeing? Is it even possible that the bearings could be on incorrectly and yet I have had no problems installing them before or setting the end play, etc?
He has me worried.
Also, are there any seals under those bearings that would need to be replaced once he pulls the old retainer and bearing off?
