Re: I need some help finding a few parts....
[Re: Dragula]
#1834943
05/26/15 11:40 PM
05/26/15 11:40 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I see a lot of paper ones on Jegs website.
[Re: Dragula]
#1835180
05/27/15 11:41 AM
05/27/15 11:41 AM
Posts: 686 PA
ajcasini
PA
Check out BO Laws Performance for carb parts. http://blp.com/They have what you need and more. I may also have a couple sets. Let me see what I have and will let you know later today.
[Re: forphorty]
#1835519
05/27/15 08:37 PM
05/27/15 08:37 PM
Posts: 12,407 Taxes & Virus's R-US, NY
Dragula
Perfect.....I will order a couple... I see a lot of paper ones on Jegs website. I bought a ton of those, and they do not hold up at all. I believe AED sells the plastic float adjustment screw washers --> aedperformance.com I will look them up.... quote=ajcasini]Check out BO Laws Performance for carb parts. http://blp.com/They have what you need and more. I may also have a couple sets. Let me see what I have and will let you know later today. [/quote] Could not find them on his site.
[Re: Dragula]
#1836479
05/29/15 07:45 AM
05/29/15 07:45 AM
Posts: 1,629 pa
572charger
pa
mine is a CSR piece from summit !!! hows the hemi !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Dragula]
#1836672
05/29/15 02:21 PM
05/29/15 02:21 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
Braswell has them, click on the gasket section. IMO best to just call and order them. I thought Quickfuel had them too but Braswell does make a lot of their stuff too. http://www.braswell.com/
[Re: 572charger]
#1837023
05/30/15 12:25 AM
05/30/15 12:25 AM
Dragula
mine is a CSR piece from summit !!! hows the hemi !!! Its pretty much done. I waited 5 weeks for an oil pan and finally gave up and used my old one after hacking it to pieces to clear the stroke. The only issue is we have a rocker stand not allowing oil to one set of the rockers. We will fix that tomorrow probably....Otherwise, its all done. How is yours coming?
