A- body 727 kickdown
#1830912
05/20/15 04:34 PM
05/20/15 04:34 PM
Posts: 275 Oakwood Ont Canada
340mouse
Oakwood Ont Canada
68 383 Cuda with a rebuilt 727 2400/2800 converter,going to use cable kickdown, but it is like pushing a car up a hill with a rope(it just bends), I don't need the kickdown, but hear It is needed for the transmission to work correct, help and options needed. Thanks
Re: A- body 727 kickdown
[Re: 340mouse]
#1830918
05/20/15 04:44 PM
05/20/15 04:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You got it installed wrong if you're trying to push with a cable. cables pull, not push. Here's Bouchillon's install instructions for your edification. http://www.bouchillonperformance.com/tqinstructions
[Re: 340mouse]
#1830926
05/20/15 04:55 PM
05/20/15 04:55 PM
Posts: 16,154 Mesa, Arizona
dart4forte
Mesa, Arizona
Is this an original big block A body. If so why not use the mechanical linkage?
Abe Lincoln
[Re: dart4forte]
#1830961
05/20/15 05:40 PM
05/20/15 05:40 PM
340mouse
Oakwood Ont Canada
Thanks SuperCuda, DUH, just had a lightbulb moment, gee how did I make it this far in life, Dart4forte, 68 383 Formula S, didn't have the linkage but had a cable kickdown given to me. I wish I had the original linkage, one day! I was doing this while recovering from surgery, I am going to use the excuse that it was the effects from meds. Thanks again guys. Dave
[Re: 340mouse]
#1831013
05/20/15 07:16 PM
05/20/15 07:16 PM
dart4forte
Mesa, Arizona
I have a kickdown setup if you need one. It was powdercoated black so that will have to come off.
Abe Lincoln
[Re: 340mouse]
#1831528
05/21/15 04:11 PM
05/21/15 04:11 PM
dart4forte
Mesa, Arizona
Fixed. Like I said when I PM'd you I looked last night and may have packed the linkage up in a box that is now in storage in Mesa. There's several other boxes that I'm getting reading to load that I'll check out this evening. I forgot to ask, do you have column on console shift?
Abe Lincoln
