12s in a challenger with a stock bottom 340?
#1829602
05/18/15 10:46 PM
05/18/15 10:46 PM
Posts: 54 US
BLACK71
US
I have a fresh short block 340 that I am looking to get into the 12s with. 30 over, stock stroke, replacement "10.5" compression pistons. No cam or heads yet. Victor intake, msd ignition...3.91s and an auto trans (2400 stall converter but realize it'll prolly need more). This is another "budget build" and not looking to run spray or forced induction.
RMNS 10:9-10
Re: 12s in a challenger with a stock bottom 340?
[Re: BLACK71]
#1829634
05/18/15 10:57 PM
05/18/15 10:57 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Set of cleaned up Eddie heads. Cam and rockers for 600 or so gross lift, mild 240 ish@50 flat tappet cam and a nice 750 carb and your there. It would get well into the12's with a different convertor.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: BLACK71]
#1829723
05/19/15 12:00 AM
05/19/15 12:00 AM
Posts: 561 USA
B3RE
USA
9.5:1 CR 224@.050 duration 273 rockers 2.02/1.6 pocket ported irons Air gap w/750 Edelbrock/650-700 Holley 1-5/8" headers/2.5" duals
12's on a budget!
Want more?
Upgrade to 1.6:1 roller rockers, and correct the geometry. Get a good 32-3500 converter
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: BLACK71]
#1829750
05/19/15 12:26 AM
05/19/15 12:26 AM
B3422W5
Portage,michigan
I bet that above combo wouldn't run 12's in a stock weight car with that 2400 stall convertor. The stock cam is about that big, and stock 340 is 10.5 compression, not 9.5. Sounds like a mid13's combo to me....... But who knows.
[Re: B3422W5]
#1829757
05/19/15 12:36 AM
05/19/15 12:36 AM
Posts: 561 USA
B3RE
USA
I bet that above combo wouldn't run 12's in a stock weight car with that 2400 stall convertor. The stock cam is about that big, and stock 340 is 10.5 compression, not 9.5. Sounds like a mid13's combo to me....... But who knows. Yeah, I originally built that combo to go high 13's in a stock weight '72 Duster. It actually had a smaller cam, performer (no RPM) manifold, and a 625 Carter AFB. It went 12.90s with a 3.55 gear and 2200 converter. Changed to 1.6 rollers, air gap manifold, and a 750 Edelbrock carb, did a little more work to the heads, and went 12.30s. It's ALL about the combination.
Mike Beachel
[Re: BLACK71]
#1829762
05/19/15 12:41 AM
05/19/15 12:41 AM
B3422W5
Portage,michigan
Great job. Surprising ET. Impressive.
[Re: B3422W5]
#1829772
05/19/15 12:54 AM
05/19/15 12:54 AM
Posts: 561 USA
B3RE
USA
Thanks!
I never expected those results myself, but it definitely changed the way I cam my engines these days, especially pump gas street motors.
I did get ahead of myself when I hit submit on that last post. I forgot to mention that we changed the gear from a 3.55 with a 25.5" tire, to a 4.10 with a 28" tire, and the converter to a 3500 when we went 12.30s. I'm sure the converter helped a lot, but the gear probably not so much with the tire change.
Mike Beachel
[Re: BLACK71]
#1829814
05/19/15 02:26 AM
05/19/15 02:26 AM
Posts: 9,859 MI, usa
dvw
MI, usa
My wife's Challenger, though it is a 360. 9-1,224@050" hyd roller. ported smog castings, LD340, 650 Holley, TTI headers and full exh. 275radials 3.55, 4 speed 2.42 1st gear. In street trim 12.70@108. doug
[Re: BLACK71]
#1829829
05/19/15 03:36 AM
05/19/15 03:36 AM
Posts: 54 US
BLACK71
US
Awesome loving the info guys and do appreciate it! I do have some altitude fighting me, 2700 and in the summer a lot of times 4000+ corrected. Ideally I'd like to run iron heads simply for the originality look but obviously there's a time to draw the line on et goals vs looks.
RMNS 10:9-10
[Re: BLACK71]
#1829862
05/19/15 08:20 AM
05/19/15 08:20 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most of our Mopars members over cam their small blocks. Matts 1970 duster runs 10.50's with a 520 solid Racer Brown cam at over 3000 pounds.
[Re: B3RE]
#1829968
05/19/15 12:44 PM
05/19/15 12:44 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I bet that above combo wouldn't run 12's in a stock weight car with that 2400 stall convertor. The stock cam is about that big, and stock 340 is 10.5 compression, not 9.5. Sounds like a mid13's combo to me....... But who knows. Yeah, I originally built that combo to go high 13's in a stock weight '72 Duster. It actually had a smaller cam, performer (no RPM) manifold, and a 625 Carter AFB. It went 12.90s with a 3.55 gear and 2200 converter. Changed to 1.6 rollers, air gap manifold, and a 750 Edelbrock carb, did a little more work to the heads, and went 12.30s. It's ALL about the combination. easier to do in a Duster. The Challenger is probably 800lbs heavier. So using a stock bottom end 340 you'll want as much compression as you can handle. You'll need a decent set of heads, decent cam, and much more stall. Now if you want to use a 440 it's much easier.
[Re: Mr.Yuck]
#1829998
05/19/15 01:09 PM
05/19/15 01:09 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
My husband's small block '72 Challenger weighs 3,340 pounds. My small block '73 Duster weighs 3,300 pounds. Both all metal body full interior street cars.
[Re: Mr.Yuck]
#1830059
05/19/15 02:26 PM
05/19/15 02:26 PM
Posts: 561 USA
B3RE
USA
I bet that above combo wouldn't run 12's in a stock weight car with that 2400 stall convertor. The stock cam is about that big, and stock 340 is 10.5 compression, not 9.5. Sounds like a mid13's combo to me....... But who knows. Yeah, I originally built that combo to go high 13's in a stock weight '72 Duster. It actually had a smaller cam, performer (no RPM) manifold, and a 625 Carter AFB. It went 12.90s with a 3.55 gear and 2200 converter. Changed to 1.6 rollers, air gap manifold, and a 750 Edelbrock carb, did a little more work to the heads, and went 12.30s. It's ALL about the combination. easier to do in a Duster. The Challenger is probably 800lbs heavier. So using a stock bottom end 340 you'll want as much compression as you can handle. You'll need a decent set of heads, decent cam, and much more stall. Now if you want to use a 440 it's much easier. The Challenger is certainly heavier, but unless it is a highly optioned BB/Hemi convertible, I doubt it's anywhere near 800 pounds. Btw, what does the compression do for it?
Mike Beachel
[Re: dvw]
#1830060
05/19/15 02:29 PM
05/19/15 02:29 PM
Posts: 561 USA
B3RE
USA
My wife's Challenger, though it is a 360. 9-1,224@050" hyd roller. ported smog castings, LD340, 650 Holley, TTI headers and full exh. 275radials 3.55, 4 speed 2.42 1st gear. In street trim 12.70@108. doug ] That's what I'm talking about, Doug! A car that is a pleasure to drive, and still gets it done when the pedal is on the mat. Very nice car!
Mike Beachel
