Page 1 of 3 1 2 3
12s in a challenger with a stock bottom 340? #1829602
05/18/15 10:46 PM
05/18/15 10:46 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
I have a fresh short block 340 that I am looking to get into the 12s with. 30 over, stock stroke, replacement "10.5" compression pistons. No cam or heads yet. Victor intake, msd ignition...3.91s and an auto trans (2400 stall converter but realize it'll prolly need more). This is another "budget build" and not looking to run spray or forced induction.
RMNS 10:9-10
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829634
05/18/15 10:57 PM
05/18/15 10:57 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Set of cleaned up Eddie heads. Cam and rockers for 600 or so gross lift, mild 240 ish@50 flat tappet cam and a nice 750 carb and your there. It would get well into the12's with a different convertor.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829723
05/19/15 12:00 AM
05/19/15 12:00 AM
USA
B3RE Offline
B3RE  Offline
USA
9.5:1 CR
224@.050 duration
273 rockers
2.02/1.6 pocket ported irons
Air gap w/750 Edelbrock/650-700 Holley
1-5/8" headers/2.5" duals
12's on a budget!
Want more?
Upgrade to 1.6:1 roller rockers, and correct the geometry.
Get a good 32-3500 converter
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829750
05/19/15 12:26 AM
05/19/15 12:26 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I bet that above combo wouldn't run 12's in a stock weight car with that 2400 stall convertor.
The stock cam is about that big, and stock 340 is 10.5 compression, not 9.5. Sounds like a mid13's combo to me....... But who knows.
1.41 best 60 foot
6.56 at 104.17
Re: 12s in a challenger with a stock bottom 340? [Re: B3422W5] #1829757
05/19/15 12:36 AM
05/19/15 12:36 AM
USA
B3RE Offline
B3RE  Offline
USA
Yeah, I originally built that combo to go high 13's in a stock weight '72 Duster. It actually had a smaller cam, performer (no RPM) manifold, and a 625 Carter AFB. It went 12.90s with a 3.55 gear and 2200 converter.
Changed to 1.6 rollers, air gap manifold, and a 750 Edelbrock carb, did a little more work to the heads, and went 12.30s. It's ALL about the combination.
Mike Beachel
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829762
05/19/15 12:41 AM
05/19/15 12:41 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Great job. Surprising ET. Impressive.
1.41 best 60 foot
6.56 at 104.17
Re: 12s in a challenger with a stock bottom 340? [Re: B3422W5] #1829772
05/19/15 12:54 AM
05/19/15 12:54 AM
USA
B3RE Offline
B3RE  Offline
USA
Thanks!
I never expected those results myself, but it definitely changed the way I cam my engines these days, especially pump gas street motors.
I did get ahead of myself when I hit submit on that last post. I forgot to mention that we changed the gear from a 3.55 with a 25.5" tire, to a 4.10 with a 28" tire, and the converter to a 3500 when we went 12.30s. I'm sure the converter helped a lot, but the gear probably not so much with the tire change.
Mike Beachel
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829814
05/19/15 02:26 AM
05/19/15 02:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My wife's Challenger, though it is a 360. 9-1,224@050" hyd roller. ported smog castings, LD340, 650 Holley, TTI headers and full exh. 275radials 3.55, 4 speed 2.42 1st gear. In street trim 12.70@108.
doug
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829829
05/19/15 03:36 AM
05/19/15 03:36 AM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Awesome loving the info guys and do appreciate it! I do have some altitude fighting me, 2700 and in the summer a lot of times 4000+ corrected. Ideally I'd like to run iron heads simply for the originality look but obviously there's a time to draw the line on et goals vs looks.
RMNS 10:9-10
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1829862
05/19/15 08:20 AM
05/19/15 08:20 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Most of our Mopars members over cam their small blocks. Matts 1970 duster runs 10.50's with a 520 solid Racer Brown cam at over 3000 pounds.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 12s in a challenger with a stock bottom 340? [Re: B3RE] #1829968
05/19/15 12:44 PM
05/19/15 12:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
easier to do in a Duster. The Challenger is probably 800lbs heavier.
So using a stock bottom end 340 you'll want as much compression as you can handle. You'll need a decent set of heads, decent cam, and much more stall. Now if you want to use a 440 it's much easier.
Coming soon!!!!
Re: 12s in a challenger with a stock bottom 340? [Re: Mr.Yuck] #1829998
05/19/15 01:09 PM
05/19/15 01:09 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
My husband's small block '72 Challenger weighs 3,340 pounds. My small block '73 Duster weighs 3,300 pounds. Both all metal body full interior street cars.
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1830013
05/19/15 01:23 PM
05/19/15 01:23 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1830018
05/19/15 01:26 PM
05/19/15 01:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
3,340 w/ gas and all fluids? I think the shipping weight on Challengers was almost 3400??? Plus a 71 Duster had a shipping weight of 2900lbs. 73's got a bunch of bumper...lol
Coming soon!!!!
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1830023
05/19/15 01:32 PM
05/19/15 01:32 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Both had 1/2 tank of gas, all fluids, same weight on 2 different certified scales. The Challenger is a 727 auto and the Duster a 4-speed. I know that heavily optioned big block/Hemi E-bodies can be porkers, especially convertibles.
The '73 Dusters do have a bunch of bumper, lol. And they have some door and roof reinforcements the earlier Dusters don't have.
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1830044
05/19/15 01:59 PM
05/19/15 01:59 PM
New York
DartS Offline
DartS  Offline
New York
My buddies 73 Challenger 340 with auto weighed 3500 when he had it weighed.
Re: 12s in a challenger with a stock bottom 340? [Re: Mr.Yuck] #1830059
05/19/15 02:26 PM
05/19/15 02:26 PM
USA
B3RE Offline
B3RE  Offline
USA
The Challenger is certainly heavier, but unless it is a highly optioned BB/Hemi convertible, I doubt it's anywhere near 800 pounds.
Btw, what does the compression do for it?
Mike Beachel
Re: 12s in a challenger with a stock bottom 340? [Re: dvw] #1830060
05/19/15 02:29 PM
05/19/15 02:29 PM
USA
B3RE Offline
B3RE  Offline
USA
doug
That's what I'm talking about, Doug! A car that is a pleasure to drive, and still gets it done when the pedal is on the mat. Very nice car! up
Mike Beachel
Re: 12s in a challenger with a stock bottom 340? [Re: BLACK71] #1830121
05/19/15 03:49 PM
05/19/15 03:49 PM
CA
crackedback Online content
crackedback  Online Content
CA
A 360, j head with an xe268H in a Demon can run 12.50's or better in the right hands.
Takes work to fine tune the combo and with an auto, the converter is key.
I would not use a victor intake on a 340 unless it has plenty of stall. The TQ the victor leaves at lower rpm compared an Air Gap is pretty big. If you have to accelerate through that range, the victor will lag.
Re: 12s in a challenger with a stock bottom 340? [Re: pittsburghracer] #1830182
05/19/15 04:57 PM
05/19/15 04:57 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
ST-21 cam? 254* @ .050??
Page 1 of 3 1 2 3
