Re: Richard Ehrenberg Master Cylinder
[Re: 6T6Cuda]
#182999
01/10/09 03:25 PM
01/10/09 03:25 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
TO those with leaky caps, have you tried lowering the fluid level a bit?
[Re: 72challorange]
#183001
01/11/09 01:14 AM
01/11/09 01:14 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I've had ZERO problems with leaking caps.
[Re: 360six]
#183003
01/16/09 10:44 AM
01/16/09 10:44 AM
Posts: 3,329 Melbourne, FL
dwbiggs
super gas
super gas
Melbourne, FL
Funny thing is, leaking cap is the main reason I ditched the original iron cyl.
Same here....thought screw on caps would eliminate the possibility of leaking...little did I know.
