Piston / Valve clearance ? w/ this combo. #182648
01/03/09 03:48 PM
01/03/09 03:48 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I recently ordered a set of KB-823's for my 451 build.
http://kb-silvolite.com/forged.php?action=details&P_id=410
I'm planning on using a Hughes 4248 solid which has .563 ex. lift.
http://www.hughesengines.com/Index/produ...mp;partid=21815
Will these two pieces work in harmony? I know the only for-sure way to tell will be to mock it up once I have the pieces, but I'm hoping someone here may have built a similar combo and can save me from buying something that wont work together.
Thanks for any help.
Edit: These pistons will be .023 in the hole, with a .040 head gasket.
Re: Piston / Valve clearance ? w/ this combo. [Re: StealthWedge67] #182649
01/03/09 06:26 PM
01/03/09 06:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Duration and cam timing play a big part in piston to valve clearence. That said we run the MP .557 cam on a 105 centerline in my sons 400 with alot of room as his eng had over .150. The KB pistons have a nice valve relief in them. I would think you will be fine but of course you will need to check it to be sure. Ron
Re: Piston / Valve clearance ? w/ this combo. [Re: StealthWedge67] #182650
01/03/09 07:31 PM
01/03/09 07:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just off hand I think you will be fine.
My 500" stroker has Keith Black pistons and had clearance for a 0.715" lift 264 @ 0.050" roller cam.
