69 383hp question
#182635
01/03/09 03:42 PM
01/03/09 03:42 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
I have a stock 69 std bore 383hp RR eng in my car and want to lighten the motor abit by putting an aluminum intake on and swap my iron hp exhaust manifolds with some yearone repops. can someone tell me the BEST intake manifold for The 383hp?? The eng has a 750 edelbrock, everything else is all stock (flat top pistons, 906 heads etc) its also an automatic torqueflite and a 3.23 surgrip BTY the motor is in a 67 satellite
Re: 69 383hp question
[Re: ngpSatellite]
#182636
01/03/09 03:56 PM
01/03/09 03:56 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I like the Performer RPM manifold, but I'm not sure how it would work with a stock cam & ex. manifold setup. with everything else left as is, I'm not sure you'll notice a difference with any manifold versus the stock piece. If you just want to lighten up a bit, and have the look of an aluminum manifold, an Eddy perfomer might be the best choice. It's basically no different than stock, just cast in aluminum instead of iron.
Personally, I'd go with headers instead of manifolds. No other bolt on part (sans a nitrous kit) can match the overall performance gain of a set of headers.
I guess the real question here, is: What is your long term goal with this motor?
[Re: ngpSatellite]
#182638
01/03/09 04:05 PM
01/03/09 04:05 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Just curious about weight reduction, are you trying to make the car lighter and faster? If that's the case then a performer rpm intake and headers would make a weight reduction of a 100# or so but would make make a huge performance gain if the engine is a stock 383hp.
Al & Sheila
[Re: StealthWedge67]
#182639
01/03/09 04:09 PM
01/03/09 04:09 PM
ngpSatellite
own private Idaho
its my mad max dooms day vehicle
Its just a hobby car to rip around town on weekend afternoons. just thought I would make a big difference?
[Re: ngpSatellite]
#182642
01/03/09 06:05 PM
01/03/09 06:05 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Thanks looks like I would pick up about 50 lbs or so. probably not worth the trouble and cost. thanks again for all the weights and measures
I didn't know the year one repops were aluminum.
[Re: ngpSatellite]
#182643
01/03/09 06:17 PM
01/03/09 06:17 PM
Posts: 3,691 MO
cdp
MO
If you could find the parts used, you could save about 50lbs with headers and intake, and pick up some HP. Probably about 40hp on a good intake swap and headers.
Mopar Muscle did a stock 383 HP rebuild and then added intake, carb, headers, etc, to the stock short block and got 450 horse total, which included a cam swap too, but otherwise a stock 383HP.
The stock type intakes are: Weind 8008, which is real close in appearance, Eld. performer 383, which accepts a TQ carb, and Eld. DP4B, also very stock appearing. A Eld. performer is good, or RPM, but may cause hood clearance issues.
Other things to look for are your radiator, which is probably 25 lbs dry and starter, which is 15 lbs. I just weighed them a while ago. An 054 Rad. and stock rebuilt starter.
Look for bargains here, ebay, craigslist, etc.
[Re: pushbutton]
#182645
01/03/09 08:09 PM
01/03/09 08:09 PM
ngpSatellite
own private Idaho
heres year one definition of there manifolds
These extremely high-quality reproduction manifolds have the correct casting numbers, pentastar logo, rust inhibited coating, and a ceramic high-heat coating that resist exhaust temperatures with a cast-iron appearance.
they don't sell cast iron anymore
