Removing Floor Wiring Panels #182548
01/03/09 02:16 PM
01/03/09 02:16 PM
Louisiana
duckblind Offline OP
Louisiana
I am trying to remove the floor wiring panels on my 68 charger. How are the secured to the floor? I do not see any welds but I can't figure out how they are attached.
Thanks.
Re: Removing Floor Wiring Panels [Re: duckblind] #182549
01/03/09 02:52 PM
01/03/09 02:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you look closer your see spot welds in the middle of the tabs
Re: Removing Floor Wiring Panels [Re: 1_WILD_RT] #182550
01/03/09 03:01 PM
01/03/09 03:01 PM
Louisiana
Louisiana
how can i remove them?
Re: Removing Floor Wiring Panels [Re: duckblind] #182551
01/03/09 03:16 PM
01/03/09 03:16 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
drill the spot welds out. You can use a spot weld cutter or a bit. A regular bit will probably end up going through the floor. Are you trying to save them for reinstallation ? if not, just take a small die grinder and slowly/carefully grind through the weld Again. too far and you will go through the floor. Oh and you did unfold them to expose the tabs that are welded to the floor right.
Re: Removing Floor Wiring Panels [Re: belv2vert66] #182552
01/03/09 03:29 PM
01/03/09 03:29 PM
Louisiana
Louisiana
yes, I opened them up to see the tabs welded to the floor. I want to save them but I am changing out the floor pan. I will order a spot weld remover from Eastwood and also get me a book on general body work.
Re: Removing Floor Wiring Panels [Re: duckblind] #182553
01/03/09 07:47 PM
01/03/09 07:47 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
I think you can buy new ones now and weld them to your new floors..
Re: Removing Floor Wiring Panels [Re: Chally426] #182554
01/03/09 09:18 PM
01/03/09 09:18 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Get the spot weld cutter. Center punch the spot weld and take it slow. Since you are replacing the floor, it shouldn't matter if you go all then way through. I just hate doing that. I just am careful all the time and it is good practice gaining the "touch" If you slip a putty knife under the edge, you can actually see/hear it pop as it seperates No reason to buy new ones if yours are good.
Re: Removing Floor Wiring Panels [Re: duckblind] #182555
01/04/09 01:42 AM
01/04/09 01:42 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
No need to wait on spot weld cutters thru mail order. If you see a Snap On truck, just run it down and get a set off them. That's what I did, and they weren't any more expensive if you count the shipping from Eastwood.
Re: Removing Floor Wiring Panels [Re: JDMopar] #182556
01/04/09 11:53 AM
01/04/09 11:53 AM
Millersville, PA
HemiChallenger Offline
Millersville, PA
Get a blair spotweld cutter (the cheapest one works the best, i swear). Center punch and drill you can feel it if you done it awhile but i noticed if you look at it outside of the bit as soon as you see rust colored dust your through. Then if it doesnt come off freely, you missed the center of the weld, no worries a screwdriver will pry it off. Just be careful not to rip the metal when doing so!
Good luck!
Steve
