Re: Pinion angle again
[Re: Monte_Smith]
#1823983
05/11/15 06:06 AM
05/11/15 06:06 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The Russians have their road rage videos - we have our pinion angle chat group sessions. One is alcohol fueled arguments showcasing poor reasoning and judgment, the other is about car crashes. I don't drink, nor have poor reasoning, so I assume you are referring to yourself. That's OK, you will catch on one of these days. Hang in there. Monte If you can't grasp the logic behind my arguments, maybe you should start using a mask or filter around the NOS. Quit sniffing the giggle spray and you might catch on. All jokes aside. Your way works for you. Use it. I feel very comfortable doing it my way, as it has worked well for me. I don't fix what isn't broke - including driveline parts.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Monte_Smith]
#1824003
05/11/15 09:09 AM
05/11/15 09:09 AM
Posts: 3,872 Smyrna, South Carolina
STEFF
And HERE it is after pages of meaningless back and forth.........is it IDEAL.....NO......does it work just fine.......YES. So bottom line, in a car with the motor mounted in the stock location, should you be overly concerned about it being "perfect"........NO, because it is simply NOT going to be. Set it within a workable angle at the rear, the front is what it is and go RACE the car.
Monte AMEN!
[Re: RV2]
#1824036
05/11/15 11:21 AM
05/11/15 11:21 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1824108
05/11/15 01:10 PM
05/11/15 01:10 PM
Quicktree
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. is it more powerful than the cars Rossler provides trannies for?
[Re: Quicktree]
#1824177
05/11/15 02:31 PM
05/11/15 02:31 PM
1967dartgt
Hilltown Pa
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. is it more powerful than the cars Rossler provides trannies for? It has a Rossler in it I believe, so yes it is. What's a 4.19@178 in the eighth? That should be in the area of 2400hp.
[Re: Monte_Smith]
#1824179
05/11/15 02:37 PM
05/11/15 02:37 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Now it all makes sense.........sit back Monte, smoke a fattie and chug a beer or three THEN you might be less tense plus you'll stop posting that this is your last post.....lmao.......
[Re: STEFF]
#1824269
05/11/15 04:27 PM
05/11/15 04:27 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Monte AMEN! Yes,but think off all the lessons in science,physics,math as well as theory and conjecture we would have missed.Thanks all for the entertainment we seen along the way.Some have been totally confused with all the astonishing utterences of information,then some have been able to learn a little.My only suggestion is always use the KISS method and leave all the scientific stuff to those smarter than us.
[Re: 1967dartgt]
#1824337
05/11/15 06:10 PM
05/11/15 06:10 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. I find it funny that, thats all you Got from all of this. And Your even Wrong about that. He set his up for parallel Too, or at least as close to parallel as you can get while under power. That would be Correct.
[Re: 1967dartgt]
#1824350
05/11/15 06:33 PM
05/11/15 06:33 PM
Quicktree
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. is it more powerful than the cars Rossler provides trannies for? It has a Rossler in it I believe, so yes it is. What's a 4.19@178 in the eighth? That should be in the area of 2400hp. it is definitely bad ass i have seen it in person. but rossler has cars that go 250mph in the 1/8 also
[Re: Thumperdart]
#1824371
05/11/15 07:10 PM
05/11/15 07:10 PM
Evil Spirit
Newport, Mi
Now it all makes sense.........sit back Monte, smoke a fattie and chug a beer or three THEN you might be less tense plus you'll stop posting that this is your last post.....lmao....... Yeah, taking your ball and going home doesn't work if you have a football - and everybody else wants to play baseball
[Re: Monte_Smith]
#1824381
05/11/15 07:21 PM
05/11/15 07:21 PM
Sport440
Canton, Ohio
[quote=Evil
NOT gonna happen Sport.........but tell you what IS gonna happen. Is that I am done with this thread and that I will continue doing it the way I have for 35+ years with good results.
And who was saying anything about production cars.........we were talking about RACE CARS and about setting pinion angle, not about making your mush mobile ride down the road smooth as glass and the joints last 100k miles.
Monte Ok, I thought we Had you, LOL Mush mobiles, no,no. My Race Car is a 73 Production car, but with a BB 600hp where a SB was mounted 1" higher. A newer rear from a late 70,s car that had the softer cushion mounts on the springs, that were ditched. Ive got two different planes, No way in ell im just setting it up so the pinion points at the rear of the tranny while under power. No way in ell, im just slapping a protractor on the pinion and setting it x amount of degrees that I might read from some book. That would be a BLIND Guess of a Whatever Pinion A. Im not Setting anything unless I know where the front u-joint is at compared to the back. Just Trying to put out good Correct info here for all of the production based Race cars that have been modified by all of the hobbiest racers out there. I will lighten up on you in the future, as you have no desire to understand pinion angle on different planes. I will Always jump in on a pinion angle debate as you stated. Thumbs up. But You and Bob G aren't far behind either. LOL You Stated something like That Sport Fury and Tony guy are the First ones to Jump in these pinion debates. That's Sport 440, by the way. Your Sport Fury was probably intended though, as a Angry implication??? Or maybe Madman. LOL, Either way I like it. Ill be in the next pinion debate as well. You Carry on as well. Good luck this season.
[Re: Sport440]
#1824415
05/11/15 08:03 PM
05/11/15 08:03 PM
1967dartgt
Hilltown Pa
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. I find it funny that, thats all you Got from all of this. And Your even Wrong about that. He set his up for parallel Too, or at least as close to parallel as you can get while under power. That would be Correct. Do you know what's even funnier sport fury, he has stated he doesn't check the front angle. I got a lot more then that from this dribble, one you don't even have a fast car and want to instruct people on how to build one. Lol now that's funny.
[Re: Quicktree]
#1824416
05/11/15 08:05 PM
05/11/15 08:05 PM
1967dartgt
Hilltown Pa
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. is it more powerful than the cars Rossler provides trannies for? It has a Rossler in it I believe, so yes it is. What's a 4.19@178 in the eighth? That should be in the area of 2400hp. it is definitely bad ass i have seen it in person. but rossler has cars that go 250mph in the 1/8 also I said on this board. Duh! Momma said you can't fix stupid.
[Re: Sport440]
#1824476
05/11/15 09:08 PM
05/11/15 09:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. I find it funny that, thats all you Got from all of this. And Your even Wrong about that. He set his up for parallel Too, or at least as close to parallel as you can get while under power. That would be Correct. I guess the pics of the Jeep drive line are as close to parallel as they could get.. and damn.. the factory did that so maybe parallel isnt the only way like you suggest EDIT And all those monster trucks better learn also.. being that they are specially build
[Re: RV2]
#1824484
05/11/15 09:12 PM
05/11/15 09:12 PM
Sport440
Canton, Ohio
Check out the next thread I start lol Did you ever get a measurement from your Pinion to your driveshaft , Like I asked?? We have your other measurements, from the axels un welded position of 11* down. I wanted to see what the pinion driveshaft angle came in at. Come on this Was your thread. But, If you don't respond, well you see what happens. Maybe those were your intentions. I haven't found your other thread yet. Measurements Please!!!
[Re: MR_P_BODY]
#1824495
05/11/15 09:18 PM
05/11/15 09:18 PM
Sport440
Canton, Ohio
I find it funny how you guys talk about you need it parrell for strength, and Monte has the most powerful car here set up "wrong" and doesn't have problems. I find it funny that, thats all you Got from all of this. And Your even Wrong about that. He set his up for parallel Too, or at least as close to parallel as you can get while under power. That would be Correct. I guess the pics of the Jeep drive line are as close to parallel as they could get.. and damn.. the factory did that so maybe parallel isnt the only way like you suggest That old Jeep has a Slip joint that band aids that. Its also Not a race vehicle. Mike, You do Parallel, Right. You Stated you build the driveline Straight. Add pinion angle from there. So hopefully its darn near parallel under power, right!! So from there you can measure directly between the driveshaft and Pinion since everything is straight. So under Power, I shoot for parallel, so do you, and monte, and so should everyone else, Shooting for Parallel is Easy on a Straight Single plane. driveline. Shooting for Parallel isn't as Easy to understand on a Dual Plane driveline for most I take it. Hence the Pinion Angle confusion argument.
[Re: Sport440]
#1824513
05/11/15 09:27 PM
05/11/15 09:27 PM
MR_P_BODY
Yes I do on stuff I build... on a production car I use the drive shaft to the pinion EDIT And years ago when this came up.. I went to talk with the people in the suspension lab at work on how they do it... they use the drive shaft to the pinion
