Re: Rear window -gasket or butyl?
[Re: beecrazy69]
#1822621
05/09/15 01:19 PM
05/09/15 01:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hello All
How do I determine if the rear window uses a rubber gasket or butyl?
The car has been apart for many years, so memory is out the window!
I have searched and it seems to go both ways, makes me more confused......Don't know if it is a year thing or what?
The car is a 71 Dodge Dart Swinger
Thank you I doesn't go both ways, it requires a gasket, there is no optional about that. You might use sealer in addition to the gasket, but I never do.
[Re: NITROUSN]
#1823315
05/10/15 11:39 AM
05/10/15 11:39 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I can't speak for this model of vehicle but....
Some gasket/glass installs on vehicles the glass are not centered into the opening, but will sit "outside" the pinchweld the gasket surrounds, so glass size will not always dictate installation needs ( gasket vs urethane/ tape kits set)..
I would recommend you make sure you have the correct back glass though......
[Re: beecrazy69]
#1823502
05/10/15 04:10 PM
05/10/15 04:10 PM
minivan
Eugene, Oregon
Just pulled out my old glass catalog..
WOW, three different selections of "Dart" 2dr models with six "6" different options for back glass #s
Swinger is broken out separately LL or LH or LM or LP with a 23 vin#.. 73 and back is the same Nags # B3861 with a size of 26X52 given ( appx)
Vin# with a "29" uses a B4439 with a size of 24X54
I cannot tell you if its a gasket or glue in with my info..
