2007 Ram 1500 Leveling kit
#1823060
05/09/15 11:43 PM
05/09/15 11:43 PM
Posts: 1,559 Michigan
Kiddart
We put a leveling kit on my sons 07 ram 1500 4x4. it really turned out nice and the truck looks much better.
My question is do I need to change the front sway bar links to something longer. they really don't sit correctly on the sway bar in my opinion??
Thanks for the replies.
Thank you Kiddart
Re: 2007 Ram 1500 Leveling kit
[Re: NITROUSN]
#1823089
05/10/15 12:15 AM
05/10/15 12:15 AM
Kiddart
I have to hear this... why is it a no no?? less rake on the front suspension?? the truck now sits level, If I would have put a complete 4 inch lift on the truck it lifts the front and the rear so I guess I don't understand. what makes it a no no??
is a complete lift kit a no no
Thank you Kiddart
[Re: Kiddart]
#1823106
05/10/15 12:34 AM
05/10/15 12:34 AM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
is a complete lift kit a no no 2 inches is all you should lift. Some struts like bilstein's have 2 inches of lift already built into them. Adding 2 additional issues with those style struts will force the suspensions operational angles to an extreme causing failure esp upper ball joints.
[Re: mod381]
#1823285
05/10/15 10:55 AM
05/10/15 10:55 AM
Kiddart
so far no vibration. we did put in 4x4 after the kit was complete just to make sure nothing was missed.
If I do get a vibration I will know what causes it.
We did look into the 2 inch bilstiens but they were out of my sons budget for now
Thank you Kiddart
