magnum transplant ?? #1821531
05/08/15 12:58 AM
05/08/15 12:58 AM
mn
flyman Offline OP
flyman  Offline OP
mn
So I put a 1993 Dakota motor into my 1957 Dodge pickup. It is now running sort of! It will start and run a few seconds and then the engine starts sounding like it is slowing down and then it will die. It will not start again unless it sits for a few minutes It is a modded wiring harness done like the info I found here on the board. I have plenty of fuel pressure and a good spark at all times. Any Ideas?? Thanks moparts!!!
Re: magnum transplant ?? [Re: flyman] #1821545
05/08/15 01:10 AM
05/08/15 01:10 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What are the error codes?
Don't be the exception.
Re: magnum transplant ?? [Re: Supercuda] #1822485
05/09/15 09:29 AM
05/09/15 09:29 AM
mn
flyman Offline OP
flyman  Offline OP
mn
The only codes it is reading are unrelated to the issue that I am having??
Re: magnum transplant ?? [Re: flyman] #1822573
05/09/15 12:09 PM
05/09/15 12:09 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It sounds like it doesn't like going into closed-loop mode. How much exhaust is behind the O2 sensor?
Re: magnum transplant ?? [Re: Jim_Lusk] #1822626
05/09/15 01:26 PM
05/09/15 01:26 PM
mn
flyman Offline OP
flyman  Offline OP
mn
There is a muffler and a short tailpipe.
Re: magnum transplant ?? [Re: flyman] #1822729
05/09/15 03:40 PM
05/09/15 03:40 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
An ODBI should be able to live without a catalytic converter (OBDII would require, at least, a cheater for the downstream O2). Put a scan tool on it and see the live data. Might tell you something.
