440 stuck fuel pump push rod #1822647
05/09/15 01:55 PM
05/09/15 01:55 PM
Hangtowner Offline OP
Is there a better tool than a bent needle nose pliers to get a stuck fuel pump push rod out? Can I get to the cam side if I take off the valley pan?
Re: 440 stuck fuel pump push rod [Re: Hangtowner] #1822672
05/09/15 02:27 PM
05/09/15 02:27 PM
I'm assuming you dont have any tapered thin jaw vice grips or you would have grabbed them by now
Re: 440 stuck fuel pump push rod [Re: Hangtowner] #1822693
05/09/15 02:49 PM
05/09/15 02:49 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If it wont just slide out, I'd bet its mushroomed on the cam end. and therefore must come out this way too.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
