Re: American Grade 8 bolts [Re: Stanton] #182248
01/05/09 08:14 PM
01/05/09 08:14 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The CHinese seem to be able to stamp whatever they want on whatever they feel like. I too would chuck those bolts in the garbage.
Sheldon
Re: American Grade 8 bolts [Re: Stanton] #182249
01/05/09 08:58 PM
01/05/09 08:58 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Grade 8 in your application is probably overkill and a waste of money. Before spending money on good bolts you should research the strengths of the various bolts and determine your needs. In this application a grade 2 bolt will probably do just fine! Don't like that, then step up to a grade 5. Grade 8 ???? Unnecessary.
A prime example here is a cross-pinning bolt that holds the blade to the shaft in a bushog mower. It would seem logical to use a strong bolt, but reality is that you want a weaker bolt that will act as a fuse if the blade hits soemthing sturdy. Better to replace a bolt than a blade...
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: American Grade 8 bolts [Re: RUNCHARGER] #182250
01/05/09 09:10 PM
01/05/09 09:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
It's always easier to spend someone else's money !!!
Re: American Grade 8 bolts [Re: Stanton] #182251
01/06/09 12:40 AM
01/06/09 12:40 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You can tell who has been burned and who WILL be burned by Chinese junk just by the responses in this thread.
I want my fair share
Re: American Grade 8 bolts [Re: SomeCarGuy] #182252
01/06/09 10:58 AM
01/06/09 10:58 AM
United States
STLDuster Offline
STLDuster  Offline
United States
I am going to start getting rid of and replacing what I have.
"No great genius has ever existed without some touch of madness." - Aristotle
