Waterpump issue... #182073
01/02/09 10:39 PM
01/02/09 10:39 PM
missouri, USA
moparmojo Offline OP
missouri, USA
Was getting the truck ready for it's winter hybernation. I threw some Sta-bil in it and took a quick 3mile drive around the block. Back it into it's parking spot and noticed the temp gauge made a quick move to the hot side. I have noticed this once before while at an intersection. It got hot fast then as quickly went back down to where it normally runs at. I shut the truck off and opened the hood to feel the radiator hose and noticed a little bit of steam and antifreeze coming from what appeared to be the gasket area on the side of where the water pump and block meet. I thought this was a bit wierd.
Is this indicative of a bad water pump or something else. That water pump probably has less than 5000 miles on it so I thought it was a bit strange. Maybe a stuck thermostat???? Any ideas?
1992 D150 5.2 fuel injected /Auto trans 120,000
Re: Waterpump issue... [Re: moparmojo] #182074
01/02/09 11:01 PM
01/02/09 11:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Sounds like a dying t-stat to me. Never seen a waterpump do anything other than leak out the weep hole when they go bad. Grab the fan and wiggle it to see if the pump bearing is bad.
T-stats are cheap, swap a new one in a see what happens???
The water pump bolts right up to the timing chain cover and not directly to the block itself. You might want to re-gasket the waterpump/timing cover if yours is leaking.
Re: Waterpump issue... [Re: Neil] #182075
01/03/09 02:10 AM
01/03/09 02:10 AM
& if it is leaking between the timing cover & the block it very well could be leaking antifreeze to the inside as well which is into the oil
Re: Waterpump issue... [Re: RapidRobert] #182076
01/03/09 04:37 PM
01/03/09 04:37 PM
missouri, USA
missouri, USA
I think I'll try the Thermostat first, then check for leaks. I was wanting to avoid pulling the pump off, but I will regasket it if the pump seems bad or there is a leak.
