I need a Hemi valve adjuster nut and cant find one
#1818832
05/04/15 09:15 PM
05/04/15 09:15 PM
Posts: 4,848 Memphis
HemiRick
Memphis
For the Dick Landy Gen 2 Hemi roller rockers....I need 1 valve adjuster nut....and can't find a similar nut anywhere....Help!?!?
Thanks Rick 901 399-0245
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: I need a Hemi valve adjuster nut and cant find one
[Re: HemiRick]
#1818926
05/04/15 11:06 PM
05/04/15 11:06 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Do you have a pic of one? That might help you find one. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1819083
05/05/15 01:16 AM
05/05/15 01:16 AM
HemiRick
Memphis
A 9/16 wrench fits it, it's 24 threads per inch and the adjuster hole is 3/8's, and the nut is only 3/16th's thick. It's hardened and black.
Unfortunately ATM my computer wont get pic off my camera....
[Re: HemiRick]
#1819096
05/05/15 01:25 AM
05/05/15 01:25 AM
Posts: 561 USA
B3RE
USA
Check out this link. These aren't blackened, which is only a surface finish, but this is what you need. Maybe you can find something blackened from another source. http://www.grainger.com/product/GRAINGER-APPROVED-Hex-Jam-Nut-1JY65
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: HemiRick]
#1819281
05/05/15 12:38 PM
05/05/15 12:38 PM
Posts: 561 USA
B3RE
USA
Looks like a winner! I was thinking after my previous post, that type of nut is what Crane, ProForm, and the RAS rockers I have use as well. Just a thought.
Mike Beachel
[Re: DusterDave]
#1819284
05/05/15 12:43 PM
05/05/15 12:43 PM
Posts: 561 USA
B3RE
USA
They both have a nice flat surface on the bottom, but are quite a bit taller, and heavier, which adds a lot of weight to the adjuster side of the rocker. I got some of the 12pt ones for my RAS rockers, but changed them back because of the lower weight.
Mike Beachel
[Re: HemiRick]
#1819355
05/05/15 02:43 PM
05/05/15 02:43 PM
HemiRick
Memphis
If the replacement nuts are thicker I figure I can grind them thinner.
[Re: HemiRick]
#1821067
05/07/15 02:29 PM
05/07/15 02:29 PM
HemiRick
Memphis
The new nuts arrived and they are standard thickness. I ground one as thin as I dare and it now weighs 5.7 grams and the original was 4.6 So I fixed it but gained 1.1 grams.
