Installing a Hood? #181920
01/02/09 06:16 PM
01/02/09 06:16 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
This may come across as some what strange. But I have 2 hoods for a car that will get painted when the car does.
One is a Repop T/A hood {ASC&P or something like that The guy also air ballons} and the other is a custom glass r/t hood that I have had since early 80's
First off I was just thinking and am no way near needing to do this at this time but will need to at a later date.
Plus I am bored.
What is the best way to remove and reinstall a hood in the same place as before
What i am looking to do is have the option of Change from the T/A black out hood to the painted R/T hood with the center black as easy a possible for a differant look.
No I would not be changing every week but would like to swap them easy.
So is ther any easy way to swap hoods?
I have seen guys say they I have seen guys say drill 2 small holes one front and one back of the hinges before removal.So they could simply incert a drill bit in the 2 holes and toss the bolts in.[ie] Drill bits pushed trew both the hindge and hood.
I can't put holes in the hindge since in a moment of crazyness I had the hinges triple plated
So I am looking at other ideas
Re: Installing a Hood? [Re: 340SIX] #181921
01/02/09 07:45 PM
01/02/09 07:45 PM
crlush Offline
crlush  Offline
you should be able to drill with a carbide drill, that would be the best bet to get you in the ballpark.just centerpunch hinges first.
Re: Installing a Hood? [Re: crlush] #181922
01/02/09 10:09 PM
01/02/09 10:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use non-permanent ink and draw lines around where the hinges rest to the hood, kinda like a Sharpie but not permanent. I detest the clowns that drill holes in sheetmetal so it makes is "easier" to re-install the sheetmetal. I would NEVER buy a car with dozens of 1/16" holes all over it...
JB Rhinehart, Realist
A-Body's RULE!
Re: Installing a Hood? [Re: Rhinodart] #181923
01/03/09 12:15 PM
01/03/09 12:15 PM
340SIX Offline OP
340SIX  Offline OP
I thiught about doing that non perm marker but the T/A hood will be black{hot rod black from dupont}
Would 1/8th inch holes make ya happier?
Yes I have seen it done before and said
Re: Installing a Hood? [Re: 340SIX] #181924
01/03/09 12:48 PM
01/03/09 12:48 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Why not just use a piece of masking tape?
Re: Installing a Hood? [Re: 469runner] #181925
01/03/09 01:05 PM
01/03/09 01:05 PM
340SIX Offline OP
340SIX  Offline OP
That was my first thought but the glue is only 14 days on tape, Hate to be using aheasive remover on flat black paint
Re: Installing a Hood? [Re: 340SIX] #181926
01/03/09 03:03 PM
01/03/09 03:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Painters tape.
Re: Installing a Hood? [Re: stumpy] #181927
01/04/09 01:09 AM
01/04/09 01:09 AM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
Tape is what I use
Re: Installing a Hood? [Re: coro500net] #181928
01/04/09 01:38 AM
01/04/09 01:38 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Just use a sharpie, they sell them in a silver color that will show up fine on your back hood. Paint over the silver later if it bothers you.
